It is currently Sat May 02, 2026 11:28 pm
 Post subject: Belt size
PostPosted: Sun Nov 16, 2008 5:35 pm
Does anybody know the belt size that I need to run the dry-sump pulley on the block (it is 5 3/8") and a CB-performance alternator pulley? I am trying to find one....but no luck on finding the size so I can get one ordered or pick one up somewhere close so I can get the motor running so I can test the new rail to make sure everything is ready to go. Any help will be greatly appreciated. Here is the info on the pulleys that I am running. Here is the Alternator pulley....http://www.cbperformance.com/catalog.asp?ProductID=1486 And here is the block pulley....http://www.scatvw.com/CrankPulleys.htm the part number is 80181 that I have now. The belt number from Scat is 80176, but no info on it and again....Thanks for your help.
 Post subject: Re: Belt size
PostPosted: Sun Nov 16, 2008 8:30 pm
Im running 1 of those trick Alt. pulleys with a power pulley.The Alt. pulley is special made so it will bring my fan speed back to stock.A power pulley with a regular size alt. pulley will slow the fan speed down,so i dont think my belt # will help you,but i'll try to find it and give it to you.Tim at Southern buggys has some of those smaller Alternator pulleys if you want one,we need all the help on cooling that we can get.
PostPosted: Sun Nov 16, 2008 8:36 pm
My belt # is 15325 and it is called Premium top cord.
