 Post subject: Msd
PostPosted: Thu Oct 16, 2014 11:28 pm
Where is the best place to buy the whole setup I never have used it so don't know where to start and what's best to buy or is their a better direction to go
 Post subject: Re: Msd
PostPosted: Fri Oct 17, 2014 12:13 am
I got mine from Jegs just because the convenience factor. I have a msd 6AL box, blaster coil and msd distributor and wires I like it especially for the rev limiter I've been known to get a heavy foot, took care of that
PostPosted: Fri Oct 17, 2014 5:03 am
I got mine from summit racing .6al box with the msd distridutor blaster coil .this set up works great for me
PostPosted: Fri Oct 17, 2014 6:14 am
jesse i have ran msd for years and i think they have a great product,but i had a 6al go bad on me twice due to moister.The first time i sent it back they repaired it and sent back,no questions.The second time they asked me what i was doing with it and i told him what we do. He explained to me the 6al was not ment for such harsh conditions and i needed their off road version. I explained that i had to sell my 6al first . MSD said no problem we will give you what you paid for it and just pay the extra for the new box. They are great people to work with,and ive been running two offr road boxes for years without problem.
PostPosted: Fri Oct 17, 2014 6:29 am
http://www.ebay.com/itm/Volkswagen-VW-a ... ea&vxp=mtr
This is the distributor I have. And I bought my 6al at swap meet I believe for 55 $ than bought new coil and wires through summit have around 250ish with everything.
No pads, No helmet, JUST BALLS!
PostPosted: Fri Oct 17, 2014 10:04 pm
Just my opinion, but this is what I'm running.
http://www.street-fire.com/cdiignition.html
Made by MSD, weatherproof and seems to be holding up great. Uses same bosch blue coil, easy to wire, and gives you a rev limiter that is adjustable by turning one of two knobs. And its cheaper.
PostPosted: Sun Oct 19, 2014 8:21 pm
I bought my entire MSD setup from Summit and bought all of the "Off Road" versions. I have been told they are epoxy filled and do better with vibrations and bumps.
PostPosted: Fri Oct 24, 2014 11:17 pm
thanks for all the info gonna go with the street fire and that cheap dist
PostPosted: Fri Oct 24, 2014 11:40 pm
I had the MSD off road and it worked great. One day my buggy just wouldn't start. Ended up the original owner didn't ground it to the battery and that fried something. I called msd and they had me test it with a volt meter and said it was shot. They can't rebuild them because they are epoxy filled. I just got another one from ebay for $45 so hopefully it works and it will be grounded to the battery. Couldn't pass up $45.
