| oil screen http://woodsbuggy.com/phpBB3/viewtopic.php?f=3&t=17283 |
| Author: | holeman [ Tue Aug 26, 2014 9:47 pm ] |
| Post subject: | oil screen |
was changing the oil in my buggy today its a dual port when i went to put the new oil screen in the round hole in the center was to small.at the parts store i told them it was a 72.what year has a bigger hole.thanks |
| Author: | holeman [ Wed Aug 27, 2014 10:07 am ] |
| Post subject: | Re: oil screen |
did i explain my problem right??????? |
| Author: | 2800passat [ Wed Aug 27, 2014 10:33 am ] |
All screens are the same to my knowledge. It is very easy to strip the 6 bolts on the plate. |
| Author: | holeman [ Wed Aug 27, 2014 1:41 pm ] |
i found magic city vw today he hooked me up.he had 3 diff oil screens will be going back there alot more. |
| Author: | 2800passat [ Wed Aug 27, 2014 6:50 pm ] |
wow! splane the 3 different screens. |
| Author: | holeman [ Wed Aug 27, 2014 7:38 pm ] |
got it fixed the old strainer had came apart and was stuck on pick up tube.now got one more question buggy has a external oil cooler with fan.how much oil is needed to fill it up.i put 3 qt in it on the dip stick it reads a qt low.is that because the oil is in the cooler or do i need to add more? |
| Author: | 2800passat [ Wed Aug 27, 2014 11:07 pm ] |
I'd crank it. Turn it off and fill to just a hair below FULL. If your motor is sitting flat flat. Always make sure your vent hose out of the Alt stand is free flowing. Those ventilating pcv boxes stop up easy and make the case build up pressure and blow oil out of the crank pulley. |
| Author: | Herbie53 [ Thu Aug 28, 2014 3:52 pm ] |
AC engines stock hold 4 quarts. External coolers and filters add about a quart to it. I would put 4 in before I started it up, let it run15-20 seconds to fill everything then recheck. |
