| cranking slow. http://woodsbuggy.com/phpBB3/viewtopic.php?f=3&t=17170 |
| Author: | KStarkey [ Fri Jul 11, 2014 7:08 am ] |
| Post subject: | cranking slow. |
my 1776 cranks slow, good battery , good power to starter. Gonna put new starter in it this weekend, got one coming from carquest for $40. Anyone ever have this problem with their starter? Wont crank fast enough to get enough spark to fire. |
| Author: | hillaholic [ Fri Jul 11, 2014 7:34 am ] |
| Post subject: | Re: cranking slow. |
Sounds like your timing is off. |
| Author: | rockrockets1 [ Fri Jul 11, 2014 9:02 am ] |
Does your starter have a nose bushing?They were out and will cause drag But in you have a automatic starter or High torx it dont use a nose bushing ...Or like Brad said may be a timing thing |
| Author: | MickeyMouse [ Fri Jul 11, 2014 6:46 pm ] |
I have had the same issue when I had a short in my starter. I have also had that happen when I did not have a good ground. |
| Author: | Roy [ Mon Jul 14, 2014 7:36 am ] |
Is your ground cable from your battery grounded directly to the starter bolt? If not, this could be your problem, just a bad ground. Try running a heavy jumper wire from the negative side of the battery to the starter bolts, see if it makes a difference. Change out the bushing in the bellhousing, this is a common problem. Take the starter apart and clean out all the rust and mud, lubricate it while you are in there. |
| Author: | KStarkey [ Mon Jul 14, 2014 12:14 pm ] |
I had already checked all the power and grounds. put new starter in her Friday and it started right up. |
| Author: | Roy [ Tue Jul 15, 2014 8:11 pm ] |
Cool, new starter. |
| Author: | KKDdaddy [ Wed Sep 17, 2014 11:33 am ] |
Check the motor on the starter and make sure it is tight. I had the same problem on one of my buggies and that's what it ended up being. Sent from my iPhone using Tapatalk |
