It is currently Sun May 03, 2026 3:15 am
 Post subject: flat spot on street rail
PostPosted: Thu May 01, 2014 4:01 pm
I just rebuilt my Webber 2BL Progressive carb and have a major flat spot as soon as I go to take off (have to pedal it to go) even after each time I shift it falls on its face. I did not buld the motor, it is a 1500 with dual port heads, Scat intake, points dist. has bigger cam ???, I just got a electronic dist. to put in soon. Does anyone have any ideas??
PostPosted: Thu May 01, 2014 4:06 pm
timing? accelerator pump?
PostPosted: Thu May 01, 2014 4:33 pm
I played with the timing bck and advanced, didn't help. The acc. pump is brand new
PostPosted: Thu May 01, 2014 6:41 pm
if its popping through the carb when it does it its a fuel if not its a timming issue. probably not advancing correctly and your new distributor may take care of it.
PostPosted: Thu May 01, 2014 7:42 pm
it's not popping so I am hoping the dist. takes care of it. Hoping I can get it done this weekend. Thanks
PostPosted: Thu May 01, 2014 8:41 pm
Check the idle jet on front side of carb toward the shroud. If it's plugged you got a flat spot.
Aircooled power!
PostPosted: Thu May 01, 2014 9:40 pm
Squirter not opening as fast as the secondary butterfly?
