It is currently Sun May 03, 2026 2:11 pm
 Post subject: full flow question
PostPosted: Sun Jan 19, 2014 9:15 pm
my motor is full flow but not routed right to take advantage so here is what i have bought and gonna run it all right question is should i run a stock cooler also and if so is it ok to run it without changing the doghouse to the one that covers it and what stock cooler should i use
i got this for my oil cooler
http://www.ebay.com/itm/Red-Aluminum-Fi ... e2&vxp=mtr
 Post subject: Re: full flow question
PostPosted: Mon Jan 20, 2014 12:00 am
Put a type 4 oil cooler on it modify the fan tin to accept the bigger cooler. run the inline cooler if you choose to . Then you are for sure not gonna overheat
PostPosted: Mon Jan 20, 2014 11:16 am
I like that will look into it
