It is currently Sun May 03, 2026 10:02 pm
PostPosted: Mon Jun 09, 2014 7:39 am
I have a duel relief case VW 1600. The relief valves were stuck, got them out. Went and bought a new set. The new set, one plunger has a "cut" in it, it is stepped. does anyone know if the cut plunger goes with the long or short spring? any info would be greatly appreciated!! Thanks!
It makes perfectly good sense if ya don't think about it.
PostPosted: Mon Jun 09, 2014 3:58 pm
Yeah I think that plunger are for a single port engine.
Both plungers should look the same.
PostPosted: Tue Jun 10, 2014 7:08 am
these plungers came in a set. The lady at LA Products said they were an upgraded set but she couldn't tell me which plunger went with what spring. The guy who would have known wasn't there. I google imaged the set and the pics showed stepped plunger with long spring which goes to the rear of engine. I installed them last night, ill see what happens. :roll:
PostPosted: Tue Jun 10, 2014 3:40 pm
That kit is probably made to increase oil pressure with the funky plunger and heavier springs.
I use an OEM case hardware kit that has the original style plungers and hardware.
I'll bet that stepped plunger is longer than the original.
