PostPosted: Mon Dec 16, 2013 11:38 pm
what you guys think would you run electric or manual?
PostPosted: Tue Dec 17, 2013 12:40 am
My buggy now has an electric pump on a 2275, but my last motor had the same carbs (40 dellorto's) with a mechanical pump and they ran great on a 2165... i like the mechanical pump personally because it doesnt give problems, but some blocks are fuel injected and you have to run electric pump.. when my electric pump takes a dump on me i will install a mechanical set up
LEGALIZE BLUEGRASS!!!
Save a tree... eat a Beaver
PostPosted: Tue Dec 17, 2013 7:54 am
I agree, I am a big fan of keeping things simple. I have never seen a Mechanical Pump fail. However, I have seen lots of electric fuel bumps leave people stranded on the trail. If the Mechanical Pump can push enough fuel to supply the carb then I would go with the Mechanical pump.
PostPosted: Wed Dec 18, 2013 10:36 pm
It's a matter of choice as to what you want to run. I personally like things simple. My buggy has a mechanical pump on it. I am running a 1915 with dual 44 Webers. The mechanical pump is great.
