| what size oil lines http://woodsbuggy.com/phpBB3/viewtopic.php?f=3&t=16347 |
| Author: | maniac g [ Fri Nov 22, 2013 7:23 pm ] |
| Post subject: | what size oil lines |
what size oil line should i use on a dry sump vw engine? with a oil filter,96 plate oil cooler,and a 5 quart oil tank.i would like to run a billet block for my oil temp and oil pressure. but that is 3/8 npt fittings old line are 1/2 npt. is the billet block not a good idea? |
| Author: | Roy [ Sat Nov 23, 2013 9:05 am ] |
| Post subject: | Re: what size oil lines |
I recommend using the same size as the input and output of your sump pump. |
