 Post subject: what size oil lines
PostPosted: Fri Nov 22, 2013 7:23 pm
what size oil line should i use on a dry sump vw engine? with a oil filter,96 plate oil cooler,and a 5 quart oil tank.i would like to run a billet block for my oil temp and oil pressure. but that is 3/8 npt fittings old line are 1/2 npt. is the billet block not a good idea?
 Post subject: Re: what size oil lines
PostPosted: Sat Nov 23, 2013 9:05 am
I recommend using the same size as the input and output of your sump pump.
