 Post subject: ratio rockers???
PostPosted: Mon Nov 04, 2013 9:50 pm
Recently got a buggy with a 2275 on the back.. its pretty stout as is but am looking for a little more off the bottom, so i was thinking on a set of ratio rockers... dual 40 dellortos, CB ultra mag heads w/ dual springs and 42x37.5 valves.. tall intakes matched ported to heads and what im sure is a 110 cam, but will verify.. jus seeing what would offer the best performance. I know 1.25 and 1.4s are popular but what about a set of 1.3 roller rockers? It was brought in a conversation with a friend who has run alot of hotrod AC motors, and he suggested it... jus looking for knowledge and opinions
LEGALIZE BLUEGRASS!!!
Save a tree... eat a Beaver
 Post subject: Re: ratio rockers???
PostPosted: Tue Nov 05, 2013 9:43 pm
reno josh here we ran 1.25 with the 110 in both motors 2332 and the 2500 and had plenty of bottom i may e wrong here but i think the more ratio you go the less bottom end you will have.
PostPosted: Tue Nov 05, 2013 9:53 pm
1.3 roller rockers would be ok on a 110. Thats as high as I would go on a W-series cam. More lift adds torque
PostPosted: Fri Nov 08, 2013 1:50 pm
I got the 1.4s on my 120 cam and feels good all over
PostPosted: Mon Nov 11, 2013 8:41 pm
Use the 1.3's. They will work good. I would up the compression ratio if you want more off the bottom. Run race fuel.
