It is currently Sun May 03, 2026 11:20 am
PostPosted: Tue Oct 29, 2013 8:43 pm
http://www.cbperformance.com/ProductDetails.asp?ProductCode=1729
Is this the correct oil cooler that everyone runs on VWs? I am not sure since i'm fairly new to buggies.
PostPosted: Tue Oct 29, 2013 8:59 pm
thats the one i have .i got a fan on mine
PostPosted: Tue Oct 29, 2013 9:12 pm
I am always looking to keep things simple. I did not want to deal with a fan, switch and relays so I ran my standard dog house cooler on the shroud and added this cooler as well as a oil filter off my engine. I ran a 2276 all day long and it never got hot
PostPosted: Tue Oct 29, 2013 9:28 pm
I ran a small one mounted on my shroud for years it worked pretty good and I went to a junkyard and found a bigger one and a fan to fit it. I wired the fan to my coil so the fan comes on went the switch does
PostPosted: Wed Oct 30, 2013 9:40 am
MM,
where did you get this style from?
PostPosted: Wed Oct 30, 2013 11:17 am
Does this brand of oil cooler hold up pretty well?
PostPosted: Wed Oct 30, 2013 11:23 am
We've run those for years, with good results.
I would get the whole kit, with thermostat that controls fan also, fan lasts forever if it doesn't have to run all the time.
I usually wire a toggle switch to control the fan also, so I can manually control the fan for long climbs.
PostPosted: Wed Oct 30, 2013 12:25 pm
MM,
You can get them all over the place. Search Aluminum Finned "Dual Pass" Transmission Cooler - 18"
It is actually made to be a Trans Cooler but worked great as an oil cooler.
PostPosted: Thu Oct 31, 2013 10:39 am
Thanks everyone for your input
