It is currently Sun May 03, 2026 12:49 pm
 Post subject: Need ideas
PostPosted: Wed Oct 09, 2013 4:09 am
I want to run oil pressure gauge and light. Also want to run oil temp gauge. My problem is...... where the sender for the light is I currently have a mechanical oil pressure gauge and the oil line for my turbo bearing. The turbo bearing feed works very well from that spot so I would like to leave it there. Where can I put the senders for everything else?
 Post subject: Re: Need ideas
PostPosted: Wed Oct 09, 2013 9:50 am
Do you have a remote filter? There should be a spot on top of it to drill and tap.
PostPosted: Wed Oct 09, 2013 9:52 am
X2 :mrgreen:
PostPosted: Wed Oct 09, 2013 9:54 am
Like this.
PostPosted: Wed Oct 09, 2013 3:21 pm
That would be for the oil pressure or temp?
PostPosted: Wed Oct 09, 2013 3:48 pm
I have a T at the block. Make sure you get the correct metric pipe thread. Sorry I forget the size. Then run pressure and light there. Then you could put the temp on the oil filter. Or if you have a type 3 case you can put the temp where the type 3 dipstick goes. They make an adaptor for it. Think it's like $12.00.
PostPosted: Wed Oct 09, 2013 4:06 pm
Cool thanks.
PostPosted: Wed Oct 09, 2013 5:08 pm
Anyone ever use the digital gauges? Dragon gauges is the name I think
PostPosted: Wed Oct 09, 2013 8:24 pm
They make a sandwich plate that You screw on between your filter that you can plumb off of. Chad :mrgreen:
PostPosted: Thu Oct 10, 2013 7:00 am
Is there any other place besides where the factory sender goes to put a oil pressure sender?
