 Post subject: Engine cylinder Diameter
PostPosted: Sun Sep 08, 2013 3:12 pm
Does a set of long barrel cylinders have a different base diameter than a set of normal cylinders? I had a block machined for 94's and got it all together and the new cylinders will not fit in the case. The cylinders are long barrels from CB Performance.
PostPosted: Sun Sep 08, 2013 11:35 pm
They are the same going into the block.....just should be longer at the top .....just for shimming reasons
PostPosted: Sun Sep 08, 2013 11:39 pm
Thats what I thought. The jugs I have will not fit in the current block but it must have been cut wrong. Thanks for the help
