| cam choice http://woodsbuggy.com/phpBB3/viewtopic.php?f=3&t=15839 |
| Author: | jesse [ Mon Aug 12, 2013 11:49 pm ] |
| Post subject: | cam choice |
So took my motor apart tonight all looked great except postons and cylinders so gonna go back with most my parts but have a choice between a 110 camn and 120 what one is the way to go and what the good and bad on them |
| Author: | The Wild Kids [ Tue Aug 13, 2013 12:09 am ] |
| Post subject: | Re: cam choice |
What's the details of your motor Jesse? 1915 or smaller I say 110, bigger motor the 120. Others may say different but that was something I was told when I built my motor. The wild kids Flipper |
| Author: | jesse [ Tue Aug 13, 2013 1:02 am ] |
its 2221 |
| Author: | Red Barron [ Tue Aug 13, 2013 9:01 pm ] |
Scat C95 Imho but what would you expect from a WC guy. |
| Author: | darrell [ Tue Aug 13, 2013 10:19 pm ] |
From what i have read on here the 110 works in all motors |
| Author: | jon williams [ Tue Aug 13, 2013 10:25 pm ] |
I run a 120 with ratio rockers (1.25) excellent performance just my 2 cents but it all depends on what your wanting to do as far as riding Sent from my MB886 using WoodsBuggy mobile app |
| Author: | kenwood [ Wed Aug 14, 2013 12:22 am ] |
Depends on gearing. 2nd gear trans run a W110 and on a 1st gear trans run a W120. Now on a stock 6 rib with that size engine W120 or just a bit bigger if heads will allow. Port and valve size, carb and vent size, weight of the buggy, and driving style will all need to be considered. FK 41,42,43 are also good choices. But a lot of factors need to be looked at. All depends on what you got and what you want to do with it. |
| Author: | jesse [ Wed Aug 14, 2013 3:21 am ] |
These 2 are my choices cause its what I all rdy have but some more info on the buggy its a 2221 motor 044 heads 542 gear trans on 38 tires and its a 2 seater 1st gear buggy and its gonna be climbing hills and trailriding I do like bottom end but also like top will the 120 kill bottom end or should it feel good with my setup |
| Author: | kenwood [ Wed Aug 14, 2013 8:22 am ] |
W110. Is what I'd run in it if it were mine. |
| Author: | jon williams [ Wed Aug 14, 2013 12:44 pm ] |
With your setup I say 120 all the way. With the 044heads you can run the ratios and Get your lift around the 500 mark and bolt on a little more power too just my opinion. I don't think you will notice a lot of bottom end loss if you do it will be minimal. Posted using the WoodsBuggy Mobile App |
| Author: | Aaron Creech [ Wed Aug 14, 2013 6:55 pm ] |
What cam was in it before? R the heads ported? Dual springs? What compression ? |
| Author: | jesse [ Mon Sep 23, 2013 1:56 am ] |
heads are stock 044s not dual spring but can change that iff needed and compression will be 11to1 now im questioning going vz15 or keep the 120 lol i cant make my mind up im just gonna stay with the 120 and hope i like it bottom end is all rdy together and not worth pulling part |
| Author: | Aaron Creech [ Mon Sep 23, 2013 9:09 am ] |
It will run just fine with that much compression. You definitely need dual valve springs. Some mild port work on the heads will wake it up even more. |
| Author: | jackson.ryan29 [ Wed Oct 16, 2013 7:40 pm ] |
Vz15 would be my choice!!! Posted using the WoodsBuggy Mobile App |
| Author: | jesse [ Wed Oct 16, 2013 11:00 pm ] |
went with the 120 and its a great cam still have my bottom and alot more top |
