| 2275 http://woodsbuggy.com/phpBB3/viewtopic.php?f=3&t=15822 |
| Author: | Ripinitup [ Sat Aug 10, 2013 6:00 am ] |
| Post subject: | 2275 |
What scat cam and what set of carbs would be a good choice for this engine? The engine kit im looking at is this one from scat... 2275 SCAT VOLKSTROKER VOLKSRACER RACE-READY ENGINE KITS This kit is race-ready and engineered for increased horsepower and pre-clearanced for longer strokes ◾Nitrided chromoly forged crankshaft ◾NEW SCAT forged H-Beam rods (Chevy or VW journal) ◾NEW Stroker AS41 dual by-pass engine case ◾NEW 'D Port' polished dual-port heads ◾NEW 3/8" cut to length chromoly pushrods ◾NEW Crankshaft Gear Assembly Kit #10207 ◾NEW 40-piece Engine Lock Nut Kit #10173 ◾NEW Universal Engine Case Hardware Kit # 10205 ◾NEW SCAT adjustable O-Ring aluminum pushrod tubes ◾NEW 4140 chromoly 8mm dual-port cylinder/head stud kit |
| Author: | Ripinitup [ Tue Aug 13, 2013 2:47 am ] |
| Post subject: | Re: 2275 |
Anyone? Posted using the WoodsBuggy Mobile App |
| Author: | jesse [ Tue Aug 13, 2013 3:17 am ] |
carbs either dual webber 40s or 44s dont know about cam |
| Author: | hpfreak [ Tue Aug 13, 2013 4:31 pm ] |
Running a c35 in my 1915 and love it. |
| Author: | gasman [ Tue Aug 13, 2013 4:33 pm ] |
If I was to run a scat cam it would be a C35. Jmo. Chad |
| Author: | Ripinitup [ Tue Aug 13, 2013 5:33 pm ] |
That's what I'm putting together rite now. 1915 c35 cam and dual weber 44s. Some day I plan to swap a 82mm crank. Just wanted to see if you could run the. c35 cam in a 2275. Seems like it would be kind of small but paired with the rite heads and carbs it should scream. Thanks for the feed back. Posted using the WoodsBuggy Mobile App |
| Author: | lpb [ Wed Aug 14, 2013 11:37 am ] |
i run a fk43 engle. 1:4 rockers. single 44 weber. runs pretty good, seems to make good power. |
