| Ordering parts for 1915 http://woodsbuggy.com/phpBB3/viewtopic.php?f=3&t=15804 |
| Author: | Ripinitup [ Tue Aug 06, 2013 4:20 am ] |
| Post subject: | Ordering parts for 1915 |
Have a few questions about my build. Here is what I have so far..... Scat builders choice engine kit C35 scat cam CB 044 heads 40x35.5 Standard weight 8 dow flywheel Block is drilled for full flow 1.5 quart deep sump My questions are.... 1 What dist. should I go with? 2 Will I need to run custom length push rods? 3 Weber 44s or 40s? Thanks in advance for the help. Everything I have done to my buggy so far the info came from here. |
| Author: | muff [ Tue Aug 06, 2013 8:42 am ] |
| Post subject: | Re: Ordering parts for 1915 |
I had to make custom length push rods but I have 1.25 ratio rockers in mine. And I have dual 44 webers on mine - runs great. Plus if you build the motor bigger later down the road you can still use them. |
| Author: | hpfreak [ Tue Aug 06, 2013 10:08 am ] |
I'm running bout the same setup. I also went with a scat kit. Works great. I'm using a petronix distributor which also works great. |
| Author: | The Wild Kids [ Tue Aug 06, 2013 11:55 am ] |
Petronix I would agree with also, it is what's on my 1915 and I run weber 40 idf duals and no issues. I had custom length push rods made to fit. |
| Author: | volksdude2007 [ Tue Aug 06, 2013 2:38 pm ] |
I run a Bosch 009 distributor with the empi brand electronic ignition I had petronix and didn't feel like forking that type of money back out for them I can't tell a difference and I also have dual weber 44s on mine and love them |
| Author: | Ripinitup [ Tue Aug 06, 2013 4:11 pm ] |
Cool. Thanks for the feed back. I have never set up my valve train but I would like to run the 1.25 rockers. It will be a learning experience. Ill go with the electronic ignition and 44s. I hope to get the parts ordered after Labor Day. Going to run the tired 1600 one more trip this year. Thanks again for the great feed back Posted using the WoodsBuggy Mobile App |
