Cam gear question
http://woodsbuggy.com/phpBB3/viewtopic.php?f=3&t=15731
Author:  Ripinitup [ Wed Jul 24, 2013 5:29 pm ]
Post subject:  Cam gear question
Im replacing the cam in my 1641 with a ENG 110. The new cam doesn't come with a gear. Do I just buy the 3 bolts and drill the rivits on my old cam to get the gear off or do I need to buy a gear to?
Author:  NRIbuggys [ Wed Jul 24, 2013 6:26 pm ]
Post subject:  Re: Cam gear question
Go ahead and put straight cut gears in it.
Author:  Ripinitup [ Wed Jul 24, 2013 11:01 pm ]
Do I need to set those up any different then the regular gears? I noticed the kit said adjustable cam gear. No idea what that means.
Author:  NRIbuggys [ Wed Jul 24, 2013 11:11 pm ]
You can get them with washers to advance or retard the timing. I'd set them with the standard washer in the kit for your motor. Kits should come with 3 sets. And the gears are marked and set up the same way.
Author:  NRIbuggys [ Wed Jul 24, 2013 11:16 pm ]
But someone else might know a little more ab the washers. It might be better for you to advance it a lil bit
Author:  Ripinitup [ Wed Jul 24, 2013 11:17 pm ]
Ok. Are the washers marked?
Author:  NRIbuggys [ Wed Jul 24, 2013 11:19 pm ]
Different colors. Black gold and silver I think. It should come with a paper that tells you what's what. Should come with lock washers and use locktite
Author:  Ripinitup [ Wed Jul 24, 2013 11:20 pm ]
Cool. Thanks for the help
