 Post subject: oil cooler leak
PostPosted: Sat Jul 20, 2013 4:56 pm
Installed doghouse oil cooler on motor and can't get it to quit leaking. Bought the motor used with bypass adapter on it and I decided I wanted extra cooling so I added the doghouse. I tried several times with the green o-rings and the red ones but still leaks. I have a regular gasket that came with another adapter but not sure if that will work either. Any help would be appreciated. And yes it is an empi cooler.
Thanks.
 Post subject: Re: oil cooler leak
PostPosted: Sat Jul 20, 2013 5:39 pm
What are you trying to do here ? Put a remote cooler adapter on it or a stock cooler ?
PostPosted: Sat Jul 20, 2013 6:12 pm
Already full flow with 96 plate and electric fan, just wanted both coolers.
