| made some air cleaner covers http://woodsbuggy.com/phpBB3/viewtopic.php?f=3&t=15692 |
| Author: | hpfreak [ Tue Jul 16, 2013 7:31 pm ] |
| Post subject: | made some air cleaner covers |
Made air cleaner covers for my kadrons. Cut up some jagermeiter ice buckets to fit what you guys think? |
| Author: | hpfreak [ Tue Jul 16, 2013 7:32 pm ] |
| Post subject: | Re: made some air cleaner covers |
Attachment: 1374017564530.jpg [ 77.63 KiB | Viewed 4099 times ] Attachment: 1374017548833.jpg [ 82.11 KiB | Viewed 4099 times ] |
| Author: | MadMike [ Tue Jul 16, 2013 7:40 pm ] |
it's cool except the bolts on the top WILL leak water. Try to find a way to secure them at the bottom of the cover |
| Author: | hpfreak [ Wed Jul 17, 2013 7:19 am ] |
yeah I agree. the bolt pulls the cover down so water will pool in the center and slowly leak in. I just need to deal with these till I can come across a canister filter. |
| Author: | davehix [ Wed Jul 17, 2013 9:07 am ] |
Rubber washer works. I have use to left over oil cooler washer . They seem to work out good. |
| Author: | Odyknuck [ Wed Jul 17, 2013 9:39 am ] |
The old style faucet washers work really well for this kind of application. They are made from hard rubber and will not compress easyly. |
| Author: | hpfreak [ Wed Jul 17, 2013 10:05 am ] |
Ok ill try that. I also thought about smearing grease all over the nut and bolt. |
| Author: | MadMike [ Wed Jul 17, 2013 12:07 pm ] |
http://www.enginaire.com/ There are several of us that use them with great success. |
| Author: | 3drinkminimum [ Sat Jul 20, 2013 2:54 pm ] |
MadMike wrote: http://www.enginaire.com/ . Are you guys running separate filter and adapters on each carb or getting a cover with venturis built in and running a snorkle type system? And where did you get the actual adapters?
| Author: | MadMike [ Sun Jul 21, 2013 1:13 am ] |
One filter, and what's a carburetor? |
| Author: | bige70chevy [ Sun Jul 21, 2013 10:21 am ] |
ran this set up for 2 years...carbs were clean as a whistle inside...
