It is currently Mon May 04, 2026 11:48 pm
 Post subject: bigger parts
PostPosted: Mon Oct 22, 2007 9:07 pm
hey i need to know the biggest crank that i can put in my 1641 without cutting the case. i ride in wellsville so i need a bit of a bigger motor because all of the people i ride with have 1915cc and bigger. the only advantage i have is my height and tires. i am planning on getting a new cank, cam, lifters, and flywheel so if you have any suggestions on what i should do please post.
dave
PostPosted: Mon Oct 22, 2007 11:47 pm
the engle 110 cam is the way to go my cousins and everyone else told me that for my 1641 they say you can really tell a difference but i run 1915 as far as crankshaft i am not sure how you could go on that dvs1 or some of the other guys would definetley know as far as the crank and other parts
PostPosted: Tue Oct 23, 2007 5:34 am
i second that ont he engle 110 cam it's great in my 1641. i bought a new stock crank for mine. get the case and heads cut and get some bigger cylinders. you could make that a 1915 with 94mm pistons and cylinders i believe. i think it is like ten bucks a hole to get your case punched out.
PostPosted: Tue Oct 23, 2007 10:26 am
yeah i was going to go with the 110. but theres also this other cam i forget what it accually is but its made to give you more low end its says its a hill climber cam. but probably a 110. ive been told by dvs1 that a 78 crank will fit in and not have to cut the case.
PostPosted: Tue Oct 23, 2007 11:52 am
With that small piston size you about have to stay with the stock stroke.
I build a spec engine that was 87x74 (1759cc) stroke and had to notch the case a bit at the cylinder opening.
You will have to cut the case with a 78.
Even then you only have a 1855cc (87 x 78 ) engine, why bother?
If you have the case apart, go with the 94mm piston kit.
1915cc with a stock 69 stroke.
Stroking a small bore engine isn't worth the trouble IMHO.
PostPosted: Tue Oct 23, 2007 7:40 pm
If your going to buy a new crank,C B Performance makes a new forged 74 stroke that is counter balanced for the same price as a 69 stroke [$179]. Throw in a 110 cam,94mm pistons,rebuilt stock rods,and a new set of heads[what ever you can afford],and you will have a great running 2054.You will have enough power to do most anything you'll ever want.I ran that size motor in my two seater with a 6 rib,street elemilater heads,duel 40 webers for about ten years.I just built a 2054 for a friends rail and he has 041 heads,and duel kardon 40's and it still runs good.You will have to buy some barrel shims for your 94's{$20] and a little grinding.But whoever builds your engine can do that very easy.JMO MIKE
