 Post subject: Brass shavings?
PostPosted: Fri May 24, 2013 9:55 pm
Pulled my valve covers to adjust my valves after break in. Found a very small amount of brass colored shavings. Drained the oil through a screen and found alot less so it seems to be concentrated in the valve covers. The oil itself was kinda brown. All very small shavings. It has me slightly scared but maybe I'm being a big baby. Any ideas? Stock rockers and set screws that I'm sure I'm over stressing with dual valve springs and large cam.
 Post subject: Re: Brass shavings?
PostPosted: Fri May 24, 2013 10:47 pm
i had the same thing happen to me on a new motor and was like WTF :shock: .. i jus figured everything had to wear in, so i changed the oil and kept a check on the pressure and never looked back 8)
LEGALIZE BLUEGRASS!!!
Save a tree... eat a Beaver
PostPosted: Sat May 25, 2013 12:38 pm
Sounds like valve guide material.
Is the rocker arm geometry good?
PostPosted: Sat May 25, 2013 8:43 pm
considering i never checked my geometry im sure its off. i didnt see it as a big problem being stock stroke and stock rockers. I'll look into though. any sugestions?
PostPosted: Tue May 28, 2013 12:39 pm
You have a degree pulley on your engine?
PostPosted: Tue May 28, 2013 3:01 pm
Valve spring retainers kissing the valve guides?
PostPosted: Tue May 28, 2013 4:34 pm
yes I have a degreed pulley. no it doesn't look the retainers are hitting
PostPosted: Tue May 28, 2013 8:15 pm
Before you spend the time checking the geometry put swivel feet in the rockers. If you run it as is its gonna beat the valve tips up. Geometry should ALWAYS be checked.
