which way do piston arrows face?
http://woodsbuggy.com/phpBB3/viewtopic.php?f=3&t=15382
Author:  hpfreak [ Fri May 10, 2013 9:11 pm ]
Post subject:  which way do piston arrows face?
as it says which way do the arrows stamped in the pistons face? finally got my heads and starting to build the top end just dont know which way the arrows face.
Author:  holeman [ Fri May 10, 2013 9:34 pm ]
Post subject:  Re: which way do piston arrows face?
toward the flywheel
Author:  hpfreak [ Fri May 10, 2013 9:37 pm ]
thank you. back to work i go.
Author:  NRIbuggys [ Fri May 10, 2013 9:37 pm ]
holeman wrote:
toward the flywheel
X 2
Author:  buggybarn [ Sat May 11, 2013 9:24 am ]
X3
Author:  holeman [ Sat May 11, 2013 10:28 am ]
your welcome
Author:  2800passat [ Sat May 11, 2013 10:52 am ]
Always have a vw manual beside you.there are always little things that big dogs think they know or forgot. For example a kid brought me a complete bug motor in pieces in a box. Well , I did not know a 1970 and down cam would not work with a 70 and up pump.It ran great for about 5 minutes. I open the book and there it was. Got a locally rebuilt Passat motor from the junk yard.If I had just took the oil pan off I would have seen someone had used too much RTV and the pick up screen was later completely clogged with rtv strings. It ran like a scalded dog for about 5 rides. Alaways look for the little things and the less obvious.
Author:  taterbug [ Wed May 22, 2013 12:42 am ]
I havent done this its just a question but what would happen if you pointed the arrows on the pistons the wrong way? Just curious
Author:  Red Barron [ Wed May 22, 2013 12:18 pm ]
Bad things
Author:  ridenrace6 [ Wed May 22, 2013 11:21 pm ]
not sure if they all are wrong what would happen, but apparently it don't #1 piston to be backwards
Author:  woogiebugger1 [ Wed May 29, 2013 4:22 pm ]
Stock rods are offset so if you put the pistons on backwards and are still able to assemble it, you will soon seize it up or break a piston. Always make sure the rods are facing the correct way too, forging marks on the rods facing up. :wink:
