 Post subject: Oil light wont go out
PostPosted: Sun Apr 28, 2013 3:43 pm
My oil light came on yesterday during a ride. I shut it down rite away. Checked oil it was good. Fired it up and headed for camp. Didnt make it cause the coil went bad. Today I changed the oil sending switch and pulled the relief spring and plunger out. All that was ok. Pulled the oil sender switch out and cranked engine over. No oil comes out of the hole. Is my oil pump bad?
PostPosted: Sun Apr 28, 2013 4:46 pm
Pull the oil pump cover make sure it's still spinning. Pull the sump screen make sure it's not clogged and your pickup hasn't come loose.
PostPosted: Sun Apr 28, 2013 10:48 pm
Ive seen the oil pump drive strip out and cause the pump to not spin. I would check that first. Just take the oil pump cover off and pull out the top gear and make sure the flat end off the drive gear isnt striped. 8)
PostPosted: Mon Apr 29, 2013 4:16 am
Ok I will check all those things. I also can hear air coming out when its cranking. Like a spark plug is out. Are these blocks know to crack anywhere? It doesnt leak any oil anywhere so if its cracked its up high somewhere.
PostPosted: Sat May 04, 2013 1:59 am
Ok. I pulled the oil pump cover and the oil pump gear was broke. Changed the pump with a used on I had and cant get any oil pressure. I tried jacking the front up all that stuff. Im going to pull the pump out of my spare engine and see if it works. I know that on is good.Also my pick up tube moves side to side a little. Is that normal? It was like that when I put the deep sump on and I ran it for a year before that.
PostPosted: Sat May 04, 2013 9:10 am
did make sure the pump was turning with the motor before you put the cover back on?
PostPosted: Mon May 06, 2013 2:06 am
I got it. I had the wrong pump in. I have a dished cam and I put a flat cam oil pump in. Im still a noob lol. Thanks HP it wasnt till I pulled the cover and seen it wasnt turning that I figured it out. :D
PostPosted: Mon May 06, 2013 7:16 pm
good deal. get that think fixed so you can break it again :twisted:
PostPosted: Tue May 07, 2013 12:27 am
Hell yea. She runs good now. Ill see what breaks memorial day when we go riding :D
