| HELP!!! This Cant Be Good!!! http://woodsbuggy.com/phpBB3/viewtopic.php?f=3&t=14936 |
| Author: | Jarhead [ Sun Feb 24, 2013 12:41 am ] |
| Post subject: | HELP!!! This Cant Be Good!!! |
Buggy has set a while! Went out and moved it out of the garage and it started pumpin oil out of the exhaust like a Texas OIl Well! ![]() ![]() Valve seals wouldnt pump that much would it? Buggy has a miss of course but fires and idles fine |
| Author: | 3drinkminimum [ Sun Feb 24, 2013 1:29 am ] |
| Post subject: | Re: HELP!!! This Cant Be Good!!! |
looks like my 1915 after sittin a minute and the #2 cylinder... rings are needed my friend... |
| Author: | afterburnt [ Sun Feb 24, 2013 12:48 pm ] |
how much oil is in the block ? is there too much |
| Author: | Jarhead [ Sun Feb 24, 2013 7:43 pm ] |
Nope she was just right! I believe where It had a miss i may have folded the rings and shes pumpin oil now |
| Author: | gasman [ Sun Feb 24, 2013 7:52 pm ] |
Jarhead wrote: Nope she was just right! I believe where It had a miss i may have folded the rings and shes pumpin oil now I'd say your right.has got to be a ring problem to be pumping like that I'd think. Chad |
| Author: | riverar321 [ Sun Feb 24, 2013 8:13 pm ] |
Mine was pumping oil like that. It turned out to have worn valve guides. One guide was floating free in the head. |
| Author: | Tim2332 [ Sun Feb 24, 2013 9:12 pm ] |
Sounds like maybe there is rust in your cylinder and you broke a ring when you started it. |
| Author: | 2800passat [ Sun Feb 24, 2013 10:04 pm ] |
whyb does jap and chevy rings last 400K miles and chineese rings last 80? |
| Author: | jesse [ Sun Feb 24, 2013 11:07 pm ] |
well its a vw they are not running their best till its leaking oil and with that much leaking i would say its got to be running damn good |
