PostPosted: Sun Feb 24, 2013 12:41 am
Buggy has set a while! Went out and moved it out of the garage and it started pumpin oil out of the exhaust like a Texas OIl Well!
Valve seals wouldnt pump that much would it?
Buggy has a miss of course but fires and idles fine
PostPosted: Sun Feb 24, 2013 1:29 am
looks like my 1915 after sittin a minute and the #2 cylinder... rings are needed my friend...
if it aint broke don't fix it
PostPosted: Sun Feb 24, 2013 12:48 pm
how much oil is in the block ? is there too much
PostPosted: Sun Feb 24, 2013 7:43 pm
Nope she was just right! I believe where It had a miss i may have folded the rings and shes pumpin oil now
PostPosted: Sun Feb 24, 2013 7:52 pm
I'd say your right.has got to be a ring problem to be pumping like that I'd think. Chad :mrgreen:
PostPosted: Sun Feb 24, 2013 8:13 pm
Mine was pumping oil like that. It turned out to have worn valve guides. One guide was floating free in the head.
PostPosted: Sun Feb 24, 2013 9:12 pm
Sounds like maybe there is rust in your cylinder and you broke a ring when you started it.
PostPosted: Sun Feb 24, 2013 10:04 pm
whyb does jap and chevy rings last 400K miles and chineese rings last 80?
PostPosted: Sun Feb 24, 2013 11:07 pm
well its a vw they are not running their best till its leaking oil and with that much leaking i would say its got to be running damn good :mrgreen:
