| what manifold?/manifold heat http://woodsbuggy.com/phpBB3/viewtopic.php?f=3&t=14900 |
| Author: | jsaylor [ Sun Feb 17, 2013 11:52 pm ] |
| Post subject: | what manifold?/manifold heat |
Single IDF center mount with no pre-heat, the current manifold has the tubes that run under the manifold. I was getting ready to do the pre-heat as described in another post in from # 2 and out to the collector. Others have stated to stay away from this type of manifold and use a manifold where the heat goes near the carb. My question is does it really make that big of a differance as these manifolds are not cheap. Thanks |
| Author: | 2800passat [ Mon Feb 18, 2013 12:05 am ] |
| Post subject: | Re: what manifold?/manifold heat |
As I mentioned a few months ago the old Germans had a 2" hose comming down from the breather to under the push rod tubs. |
| Author: | jsaylor [ Mon Feb 18, 2013 12:38 am ] |
As I had mention some time ago I don't have a place to insert a 2 inch tube on my air cleaner, I'm using a weber air cleaner. Unless perhaps I'm not following. Thanks so much. |
| Author: | Red Barron [ Mon Feb 18, 2013 11:47 am ] |
Can you make a tube like the one pictured and braise it on your manifold?
| Author: | jsaylor [ Mon Feb 18, 2013 7:18 pm ] |
That loogs good, thanks |
| Author: | MadMike [ Mon Feb 18, 2013 8:11 pm ] |
I have a set of heat riser tubes if you want them.
| Author: | jsaylor [ Wed Feb 20, 2013 12:21 am ] |
Yes, this is what I've been looking for, how much? can you ship them? |
| Author: | MadMike [ Wed Feb 20, 2013 12:52 am ] |
I'll give them to you, just pay shipping. PM me. |
| Author: | MadMike [ Wed Feb 20, 2013 1:21 pm ] |
The tubes are on their way, hope they help. |
| Author: | jsaylor [ Wed Feb 20, 2013 10:40 pm ] |
Thanks so much for all the help |
