PostPosted: Sun Feb 17, 2013 11:52 pm
Single IDF center mount with no pre-heat, the current manifold has the tubes that run under the manifold.
I was getting ready to do the pre-heat as described in another post in from # 2 and out to the collector. Others have stated to stay away from this type of manifold and use a manifold where the heat goes near the carb. My question is does it really make that big of a differance as these manifolds are not cheap.
PostPosted: Mon Feb 18, 2013 12:05 am
As I mentioned a few months ago the old Germans had a 2" hose comming down from the breather to under the push rod tubs.
PostPosted: Mon Feb 18, 2013 12:38 am
As I had mention some time ago I don't have a place to insert a 2 inch tube on my air cleaner, I'm using a weber air cleaner. Unless perhaps I'm not following. Thanks so much.
PostPosted: Mon Feb 18, 2013 11:47 am
Can you make a tube like the one pictured and braise it on your manifold?
PostPosted: Mon Feb 18, 2013 7:18 pm
That loogs good, thanks
PostPosted: Mon Feb 18, 2013 8:11 pm
I have a set of heat riser tubes if you want them.
PostPosted: Wed Feb 20, 2013 12:21 am
Yes, this is what I've been looking for, how much? can you ship them?
PostPosted: Wed Feb 20, 2013 12:52 am
I'll give them to you, just pay shipping. PM me.
PostPosted: Wed Feb 20, 2013 1:21 pm
The tubes are on their way, hope they help.
PostPosted: Wed Feb 20, 2013 10:40 pm
Thanks so much for all the help
