It is currently Mon May 04, 2026 1:52 am
PostPosted: Fri Feb 15, 2013 7:45 am
I'm starting to gather everything to add power steering, is anyone running two vbelts with a pump if so how and maybe some pics would help me figure it out. I want to make pump bracket so I can adjust tension with it but not sure if dual belts are easily doable.
PostPosted: Fri Feb 15, 2013 9:11 am
Hopefully afterburnt or davehix will chime in on this.but while you wait look up afterburnt2276 on youtubd, he made a little video showing his setup. Cant remember who sells it but he runs double crank pulley
"IT IS WHAT IT IS"
PostPosted: Fri Feb 15, 2013 10:16 am
This is a c4 pump of ford taurus i made a bracket of the alternator stand and used pulleys from tractor supply.. has worked great for six years now and the motor is a 2387..ImageImageImage
PostPosted: Fri Feb 15, 2013 1:18 pm
Jayrod you run power steering right? Do you run one belt around alternator and pump? If so how does one belt hold up? Thanks
PostPosted: Fri Feb 15, 2013 4:47 pm
A friend of mine ran a single belt for years and it worked .
i run a double pulley set up with the add on pulley . saco sells a bolt on pulley for like 30 bucks. and you can buy a bolt on pump bracket for 100.00 off pacific customs.
PostPosted: Fri Feb 15, 2013 4:56 pm
here are some links to a set up like mine. i dont have any pics.
http://www.pacificcustoms.com/mm5/merch ... ange_high=
http://sacoparts.com/proddetail.php?prod=64-4150
http://www.ebay.com/itm/Sweet-Power-Ste ... 9d&vxp=mtr
PostPosted: Fri Feb 15, 2013 6:41 pm
the pump i used is out of a geo storm, I made the mount but if you dont have the equipment you would be better off buying the mount somewhere, they have some nice ones out on the market. the pulley is a double pulley i bought from competition engineering. the website is www.cevw.com the pulley was about 100 bucks and the quality is top notch. i tried running the pump off of a single belt around the alternator but every time id hit a puddle, the belt would squeal. there is really not enough belt on that pulley to grip it. for the gear box, i used one out of a jeep Cherokee. you can get one out of a junk yard and it works pretty good. personally after having power steering after a few years, i dont know how i ever road without it.
PostPosted: Fri Feb 15, 2013 6:53 pm
Thanks everyone for the help I gotta figure out what route I'm Gona take ill post pics when its done.
