It is currently Sun May 03, 2026 3:41 pm
Post new topic Reply to topic  [ 39 posts ]  Go to page 1, 2  Next
 Post subject: Rev limiter
PostPosted: Tue Feb 05, 2013 9:17 pm
http://vwparts.aircooled.net/Pertronix- ... -p/600.htm
Anyone ever use one of these? Opinions?
"IT IS WHAT IT IS"
 Post subject: Re: Rev limiter
PostPosted: Tue Feb 05, 2013 9:29 pm
They work great!!!
Hold up to mud good too!
Easy to use and install.
PostPosted: Tue Feb 05, 2013 9:36 pm
sweet. Ima order one then :D
"IT IS WHAT IT IS"
PostPosted: Tue Feb 05, 2013 9:38 pm
is it compatible with the electronic ignition, I don't run points
"IT IS WHAT IT IS"
PostPosted: Tue Feb 05, 2013 9:40 pm
This is compatible with points, and all points replacement devices (Pertronix, Compufire, Compu-tronix, Crane, etc).
Just read that on the page. duuuhhh lol
"IT IS WHAT IT IS"
PostPosted: Tue Feb 05, 2013 10:06 pm
A beer can rolled under my gas pedal once. It worked great.
PostPosted: Tue Feb 05, 2013 10:17 pm
hahaha.... How do ya figure where you should set the limiter too?? or do i just go off the point the cam stops making power
"IT IS WHAT IT IS"
PostPosted: Tue Feb 05, 2013 10:21 pm
here is a msd rev limiter from summit
http://www.summitracing.com/parts/msd-8728/overview/
PostPosted: Tue Feb 05, 2013 10:26 pm
hmm wonder if thats better than the petronix setup, petronix is way more adjustable though.
"IT IS WHAT IT IS"
PostPosted: Tue Feb 05, 2013 11:07 pm
The only problem with the msd limiter even though its cheaper is that you have to run the msd 6 or better box if I remember right.
I have mine set for 1500 after 15% power loss...but that is not a scientific or a race tech set up its my insurance policy for my motor so I don't blow it....or if someone doesn't know what they are doing and dump it dump the motor at the same time
PostPosted: Wed Feb 06, 2013 12:46 am
there are 2 versions, the one i posted is supposed to work with points and oem electronic ign so it should work fine
PostPosted: Wed Feb 06, 2013 12:57 am
Sweet!....I say this to my gf and to people that do the inventory in stores when I'm looking for an item...I love to be proven wrong! This way I learn something new or find what I need in another spot.
PostPosted: Wed Feb 06, 2013 9:51 am
Ima go with the petronix, think the adjustability is worth the extra little bit.
"IT IS WHAT IT IS"
PostPosted: Wed Feb 06, 2013 6:28 pm
how about a MSD 6AL box thats what i run .they have rev limiter chips.the msd will give you more HP.I run a 6600 chip
PostPosted: Wed Feb 06, 2013 9:40 pm
Cant afford that setup. Would havta buy the Box, distributor and coil wouldn't I ?
"IT IS WHAT IT IS"
PostPosted: Wed Feb 06, 2013 10:39 pm
no just a box will work. look up msd 6al manual and it will show you how. You can add the distributor later.You dont need a new one look around and find a used one.I just found 2 on Buycheapr.com for $125
PostPosted: Thu Feb 07, 2013 5:58 pm
just found 2 6al boxes on racingjunk $125 each
PostPosted: Thu Feb 07, 2013 6:42 pm
I think ima just go with the petronix. That way if it fails, Im not dead in the water and have to get another box to be up and running. simply eliminate it. Don't ya have to use the MSD Coil with the box?
"IT IS WHAT IT IS"
PostPosted: Thu Feb 07, 2013 11:35 pm
no you dont need a MSD coil and if it craps out you can unwire it and run with out it. I have good luck with it and i do have a spare box in the trailer. hix is the only one that needed it but he had the digital box and he got rid of that and got a 6AL box . i did notice a big difference with the MSD it starts a lot easier and runs stronger . On the back page of the insulation instruction book, it does show how to hook it up to a petronix ignitor kit. What it shows is a white and red wire out of the msd box, you hook it to your ignitor. The black wire from the ignitor goes to the white wire of the msd box. The red wire of the ignitor goes to the red wire of the msd box which is also hooked to your ignition key. Now there is an orange wire from the msd box that goes to the plus side of the coil, and the black wire goes to the negative side of the coil. Then you also have a red and black heavy wire from the msd box that goes to the battery. It looks pretty easy. I will scan the diagram tomorrow and put it up for you to look at.
PostPosted: Thu Feb 07, 2013 11:41 pm
If you say that's the way to go, Ill go that route aslong as it all works with the parts Im using now until funds allow the good stuff.
"IT IS WHAT IT IS"
PostPosted: Thu Feb 07, 2013 11:57 pm
YEP it will work and you will like it :D
PostPosted: Fri Feb 08, 2013 12:08 am
http://www.racingjunk.com/Ignition-Spar ... n-box.html
This the right one?
"IT IS WHAT IT IS"
PostPosted: Fri Feb 08, 2013 12:11 am
http://www.racingjunk.com/Ignition-Spar ... -6420.html
Or that one? same thing
"IT IS WHAT IT IS"
PostPosted: Fri Feb 08, 2013 12:14 am
I could wait...Theres another pro-formance swap meet in canton march 2nd-3rd :wink: :wink:
"IT IS WHAT IT IS"
PostPosted: Fri Feb 08, 2013 8:16 am
here you go jayrod, the way it looks this msd will fit everything. and i looked up the list on the coils and its compatible with just about every coil out there, they have a big list. Does this mean you are going to that swap meet next month?
