| Need manifold heat http://woodsbuggy.com/phpBB3/viewtopic.php?f=3&t=14768 |
| Author: | jsaylor [ Thu Jan 31, 2013 7:42 pm ] |
| Post subject: | Need manifold heat |
I have a 1843 single weber carb with an empi manifold, after market exhaust, the tubes that came with the manifold are missing and the headers don't have a place to instal the heat. I've looked at a few post that take from the # 2 and exit to the collector. what parts do I need? can't seem to find the tubes that go from the intake to exhaust, do I just make my own? as far as the connection to the header do I purchase the block offs the drill a hole? Thanks |
| Author: | 2800passat [ Thu Jan 31, 2013 8:48 pm ] |
| Post subject: | Re: Need manifold heat |
run a 2" hose from your air cleaner to down under your push rod tubes. |
| Author: | jsaylor [ Thu Jan 31, 2013 8:52 pm ] |
Does that work very well? I have a weber style air cleaner without place to connect a hose |
| Author: | hpfreak [ Thu Jan 31, 2013 9:10 pm ] |
did you really thinking asking in a different thread would help? http://www.woodsbuggy.com/index.php?option=com_jfusion&Itemid=109&jfile=viewtopic.php&f=3&t=14618 just kidding i have looked around and cant seem to find the tubes either. unless you buy a whole manifold. but the tubes are useless without the ports on the exaust. i like the idea about running oil through the manifold but not easy without full flow. i would go with the idea of grip heaters the closer you can get them to the carb the better they will work. |
