It is currently Sun May 03, 2026 11:20 am
 Post subject: Gauges
PostPosted: Mon Jan 14, 2013 9:23 pm
Need some help on gauges. Looking to install an oil temp gauge and an old pressure gauge. It will be in a 1641. No idea on how to do it or what exactly to do.
Thanks Ryan
WTFO
Loud pipes save lives.
 Post subject: Re: Gauges
PostPosted: Mon Jan 14, 2013 11:55 pm
youll just need to run a tee off the port on the engine so you can run 2 senders or ive seen some oil temp senders that replace your dipstick. but if your going to be racing the last thing youll be paying attention to is a gauge. In my opinion its much better to run bright lights to warn you of low pressure or high heat maybe even hook them up to a horn its hard to ignore a loud horn. dont forget a voltage light to tell you your belt flew off and your fans not turning.
PostPosted: Tue Jan 15, 2013 12:00 am
get yourself one of these books and read it. lots and lots of great information.
http://www.amazon.com/Baja-Bugs-Buggies-VW-based-off-road/dp/0895861860
PostPosted: Tue Jan 15, 2013 12:22 am
i run a guage and a red light...ran a T off block, put sending unit on one side for light and tube for guage on oyher side of T. pretty sure light is set to come on if pressure is under 5 pounds also have green light for alt.....when they come on they defenetly get your attention! and guages are a must for sure an oil pressure guage so you know what your motors up to
PostPosted: Tue Jan 15, 2013 12:30 am
i never did like the mechanical pressure gauges. i just dont trust a plastic line holding back oil pressure. im sure oil wouldnt come out at an alarming rate if it broke but nor does a vw hold alot of oil. on the same note ive seen senders bust and spew oil but atleast the light comes on when a sender busts. to each there own both ways are certainly better than nothing and a mechanical gauge is much cheaper.
