 Post subject: Heating my manifold?
PostPosted: Tue Jan 08, 2013 8:23 pm
1835 vw with single weber, has any one tried using heated snow mobile hand grips to heat their manifold?
any other ideas?
 Post subject: Re: Heating my manifold?
PostPosted: Tue Jan 08, 2013 8:54 pm
Old stock beetles ran a 3" hose out of the air cleaner down below to the push rod tubes.Now that will keep yo wig wome.
PostPosted: Tue Jan 08, 2013 11:14 pm
I remember seeing at one time one this site how to modify your exhaust so you run heat tubes for your manifold, does anyone know of this post?
PostPosted: Sun Jan 13, 2013 4:36 pm
If your running a IDF the aluminum low profile manifold with the slide in heat riser tubes works best. Having your carb jetted right helps too. The single IDF works fine in warm weather without heat risers but cold weather not so good because of fuel separation. I ran a single 40 on the New Years ride with no heat risers on ethanol the manifold had ice on it heat risers would have been a big help.
Travis
PostPosted: Sat Jan 19, 2013 10:50 pm
I have a weber progressive and I tapped the manifold where the tubes go in, with a 3/8 pipe tap, installed barb fitting and ran oil threw it before it went to the remote oil cooler, works very well. You need full flow oiling to do this.
PostPosted: Mon Jan 28, 2013 10:51 am
I hard piped mine I beleive I have some pictures on my buggy build .. Search the samba . There's many ways to do it and try are all very well covered there. That's we're I got my info .. Mine works great for heating the intake but my progressive is still junk and runs real bad down low .. Duals are my next step.
