| Udo Becker lifters http://woodsbuggy.com/phpBB3/viewtopic.php?f=3&t=14551 |
| Author: | jayrod [ Fri Dec 28, 2012 7:05 pm ] |
| Post subject: | Udo Becker lifters |
Tool steel lifters, No cam break in, reusable.... Aircooled.net shows them for $400 really thinkin about holding off on completion of my motor until I can afford these...Opinions?? |
| Author: | giveitagallon [ Fri Dec 28, 2012 7:18 pm ] |
| Post subject: | Re: Udo Becker lifters |
Are lifters a common failing issue on vw's ? I never saw them come apart unless their was a explosion on the inside . But then again I never built a high dollar vw ! |
| Author: | jayrod [ Fri Dec 28, 2012 7:25 pm ] |
well if not broke in properly it causes a major problem right off the get go, But the more I read online theres horror stories about all lifters except these lol. The difference is in the hardening process blahg blah blah . Buy these- No break in, Never buy lifters again- Supposedly. |
| Author: | jayrod [ Fri Dec 28, 2012 7:29 pm ] |
But last time I was up at Jims- I was told by them that I could buy the Empi lifters he has sitting there and I would have no more or less worries than if I bought something else - say scat , cb, bugpack, etc... |
| Author: | jayrod [ Fri Dec 28, 2012 7:41 pm ] |
http://www.mofoco.com/item/EMPI_21_4300 ... 8/363/c144 If you read on this page where Empi lifters are for sale, It says- Note: Installation with Engle Cams is required to maintain Camshaft warranty So to maintain the warranty on my engle cam I should use empi lifters? lol So engle clearly has no problem with them? ey? |
| Author: | 2800passat [ Fri Dec 28, 2012 8:35 pm ] |
HOW MANY PEOPLE HAVE HAD A WARRANTY STAND?AND IF THEY DO, ARE THEY GOING TO COVER THE EXPLODED MOTOR AND YOUR TIME OR THE BITS OF METAL LODGED IN YOUR OIL PASSAGES HIDIND AND WAITING ON YOUR NEW BUILD! ? ARE THEY GOING TO PAY THE 4X4 GUY TO WINCH YOU OUT OF THE CANYON? THE NEW OIL, GASKETS, RTV, ETC! |
| Author: | jayrod [ Fri Dec 28, 2012 8:46 pm ] |
LOL easy killer...Im just posting what ive found in my readings... it blows my mind how something so bad can be recommended by some. especially from jims..Thats what got the wheels turning in my head. |
| Author: | Aaron Creech [ Fri Dec 28, 2012 8:54 pm ] |
They are a very nice piece,but in my opinion its overkill. If you were gonna be swapping cams left and right or running crazy RPM and spring pressure I would say go for it. |
| Author: | jayrod [ Fri Dec 28, 2012 9:16 pm ] |
nuff said |
| Author: | bige70chevy [ Fri Dec 28, 2012 10:03 pm ] |
i had a problem with a brand new lifters and cam set...engle and engle...during break in i had on rocker keep getting loose...after about 3 10 minute runs it had ate the lifter alive....called k1 where i bought them and he said 1 out of every 100 cam/lifter combos that they sell,fails...no matter what the combo...engle/engle...engle/scat...etc. anyway he said as long as i used the zinc infused break in oil,which i did, that engle would do an exchange also k1 said he would sell me whatever parts i needed to fix motor at discount if it did do any other damage. rons machine in dayton also offered to remachine any parts for free for me if needed,,,engle gave me no probs and sent me new cam and lifters and i ended up sending block to brothers in cali to have lifter bores sleeved...its been running like a beast ever since |
| Author: | jayrod [ Sat Dec 29, 2012 9:41 am ] |
good to know they atleast try to take care of ya, Was the cause of the problem the lifter bores from the beginning though? |
| Author: | bige70chevy [ Sat Dec 29, 2012 8:55 pm ] |
no the lifter bores were ok but figutred it was cheap insurance on a motor i planned on keeping....they said the problem is metalergy(may not have spelled that right) the lifters were too soft they wore evenly...unlike bad bore which from what ive heard will just dif a big groove |
| Author: | afterburnt [ Sat Dec 29, 2012 8:55 pm ] |
when i bought my eagle fk8 cam from jim he set me up with empi lifters .there working just fine |
| Author: | jayrod [ Sat Dec 29, 2012 11:15 pm ] |
serious!?? I just ordered engles last night damnit. Knew I shoulda listened to him lol O well. |
| Author: | ridenrace6 [ Sat Dec 29, 2012 11:29 pm ] |
i hope yall the best of luck with those empi lifters here are some alternatives to the udo becker lifters and they are supposed to be 100% made in the USA http://www.4secondsflat.com/Volkswagon% ... ifters.htm also the slr lifters with the parkerized coating is supposed to last, or you can send your own lifters and they will do the mod to them |
| Author: | vwtravis [ Sun Dec 30, 2012 11:21 am ] |
Damn $525 for lifters! I built my last 2 motors for less then that! |
| Author: | bige70chevy [ Sun Dec 30, 2012 11:26 am ] |
i ended up going with the engle cam and slr lifters....motor has ran great for 2 years its at mystic performance now for some port n polish on the heads and a check up on other internal parts....ill let you know how everything has held up |
| Author: | jayrod [ Sun Dec 30, 2012 11:35 am ] |
you can get the udo beckers for $400, But I went with Engle FK8 an engle lifters, If I Have any problems I will be getting the udo's |
| Author: | Aaron Creech [ Sun Dec 30, 2012 1:14 pm ] |
I just built an engine for myself using an Engle cam and lifter combo.The engine is back apart now for some oiling modifications but the cam/lifters look great.I even broke it in with heavy dual springs. Use Brad Penn 30wt break in oil. |
