| Lifters http://woodsbuggy.com/phpBB3/viewtopic.php?f=3&t=14493 |
| Author: | jayrod [ Sat Dec 15, 2012 7:02 pm ] |
| Post subject: | Lifters |
Will be running an Engle FK 8 , Just wondering different opinions of lifters before I order them. |
| Author: | ridenrace6 [ Sun Dec 16, 2012 6:25 am ] |
| Post subject: | Re: Lifters |
a lot of folks say use engle lifters with engle cams, scat lifters with scat cams, cb lifters with cb cams, etc, etc.... with that being said, i have used the scat lube-a-lobes with engle cams in a couple of engines without issue so far, however if you go that route call scatvw and talk to ron to make sure you get the right ones, i cant remember the part numbers but they have 2 different sets of the lube-a-lobes, one is lighter than the other and will not last as long of course the cb 2 piece lightweights get pretty good reviews on the samba but ive never used any myself and of course if money permits the udo becker tool steel lifters come highly recommended from a lot of folks |
| Author: | afterburnt [ Sun Dec 16, 2012 11:28 am ] |
WOW! a fk8 what rockers you running |
| Author: | Aaron Creech [ Sun Dec 16, 2012 12:45 pm ] |
I have had good luck out of the SLR treated scat lifters as well as the CB 2 piece. The Engles are a nice piece as well. No matter what,make sure your lifter bores are TIGHT or nothing will last.The FK-8 is a great cam,but I would have it ground on a different lobe center. |
| Author: | jayrod [ Sun Dec 16, 2012 1:15 pm ] |
Dave, It'll have 1.4 rockers. Thinkn ill go with the engles. Just fishing for opinions lol |
| Author: | jayrod [ Sun Dec 16, 2012 1:17 pm ] |
Far as lifter bores go , ill check them, if theres any issue ill getm sleeved |
| Author: | afterburnt [ Sun Dec 16, 2012 4:26 pm ] |
as you seen that setup works great on my bug |
| Author: | jayrod [ Sun Dec 16, 2012 5:02 pm ] |
You run an FK 8 ? |
| Author: | afterburnt [ Sun Dec 16, 2012 7:45 pm ] |
yea |
| Author: | jayrod [ Sun Dec 16, 2012 7:53 pm ] |
lol....Im almost ready for assembly!!! |
| Author: | afterburnt [ Sun Dec 16, 2012 8:04 pm ] |
what kind of case are you using? If you are using a stock case, make sure there is room for the lifters when its on high lobe. the one case i had, i had to have jim cut the top of the lifter boards down to make room for a bigger cam. |
| Author: | jayrod [ Sun Dec 16, 2012 8:07 pm ] |
Yea , im waiting on lifters to get here. Hopefully they dont take forever. |
