| what oil pump do you run? http://woodsbuggy.com/phpBB3/viewtopic.php?f=3&t=14340 |
| Author: | ihcguy [ Mon Nov 12, 2012 11:42 am ] |
| Post subject: | what oil pump do you run? |
Sending Empi back. Wanted to run filters off of it with the in and out port and leave doghouse cooler. What is the best tried and true setup on these? I see that Melling pumps are built in the USA. Will the Melling pump provide enough pressure for engine while feeding a external mounted cooler and dual filter assembly? Just not real familiar with these engines yet. Appreciate your help on this. |
| Author: | Aaron Creech [ Tue Nov 13, 2012 12:08 am ] |
| Post subject: | Re: what oil pump do you run? |
The Bugpack super pump is a good quality part. Get the block full flowed.It can be done with the engine together.I do not like the melling pumps,them being made of steel causes oil leaks due to different expansion rates of the two materials. |
| Author: | ihcguy [ Tue Nov 13, 2012 9:08 pm ] |
Will do just that. Thanks Aaron for your help. |
| Author: | turboblue [ Wed Nov 14, 2012 1:16 pm ] |
A Schadek 26mm pump with a full flow cover is a good combination. Melling cast pumps will leak pressure as Aaron suggests. |
| Author: | Aaron Creech [ Wed Nov 14, 2012 10:17 pm ] |
If you need help with getting the block done,let me know. |
| Author: | RaceBugg1098 [ Thu Nov 15, 2012 12:27 pm ] |
I have run sevral melling pumps with out any problems with them leaking. They are the best oil pumps I've ever used. The only issue I have had with them is trying to pull one out of an assembled motor. I wouldnt run anything else. |
| Author: | turboblue [ Thu Nov 15, 2012 6:25 pm ] |
RaceBugg1098 wrote: I have run sevral melling pumps with out any problems with them leaking. They are the best oil pumps I've ever used. The only issue I have had with them is trying to pull one out of an assembled motor. I wouldnt run anything else. They few I've tried to use were loose in the case. As long as they are tight they will work. |
