 Post subject: question on new oil pump
PostPosted: Sat Nov 10, 2012 9:22 am
Just installed a new oil pump with the fittings to pump oil to my aftermarket filters. Question is it seems that it does not fit snug enough in the block to seal the ports on each side. Won't this cause a loss of pressure? Just seems like it should fit very snug to seal against the ports. Like I should have to tap it into place with a dead blow hammer? It is an empi pump I just purchased from Chirco.
PostPosted: Sat Nov 10, 2012 11:42 am
Yes the pump should fit fairly tight in the bore. If it does'nt it will suck in air on the pickup side and and bleed off pressure on the outlet.
PostPosted: Sat Nov 10, 2012 4:30 pm
with a part as important as oil pump...id stay away from empi...jmo
PostPosted: Sat Nov 10, 2012 8:59 pm
So Empi does not make good stuff? Won't buy anymore. Just needed a pump to direct oil to filters. Block is not a full flow block and leaving doghouse cooler. Does the oil pump on these usually slip right in or do you usually have to press it to say into block?
PostPosted: Sun Nov 11, 2012 9:22 am
A new oil pump should have to be tapped into the block with a dead blow or a piece of wood and a hammer. I always leave the case half bolts loose in the oil pump area, install the pump, then torque the case halfs after it's driven home. Even doing it this way it should still fit tight. If you have a pump that fits loose, I would get my money back. Do not use it.
PostPosted: Sun Nov 11, 2012 10:37 am
over the last few years i havent had (as welll as others on here)very good luck with empi...china made crap....if its a sun visor or something, may be ok, but cv joints,axles,etc, not very good quality and doesnt last...and racetrim is empi also.
