It is currently Tue May 05, 2026 12:29 am
PostPosted: Sat Jul 28, 2012 1:29 pm
Okay so my wife got me a new 2 KW Compu fire starter for my buggy. It is a 2180 motor I have been having problems with a standard starter not being able To turn it over. I put it on and it seems to sound like it is binding. what do I need to do to shim the starter I have never done this before with any of the starters in the past but I've had.
PostPosted: Sat Jul 28, 2012 1:57 pm
Are you sure you got the right starter for the right bellhousing?
PostPosted: Sat Jul 28, 2012 3:03 pm
I have a six rib transmission. I put a three rib bell housing onto my six rib.The starter I bought this for a three Rib bell housing . it all bolts up fine but seems like the starter gear and the Flywheel gear are too Tightly matched.
PostPosted: Sat Jul 28, 2012 8:28 pm
I would compare the two starters side by side. Make sure the shafts are the same size and the gear is the same.
PostPosted: Sat Jul 28, 2012 9:14 pm
This might sound funny but are all your connections good and clean? is there paint under ground connection? check and clean all battery connections.
PostPosted: Mon Jul 30, 2012 8:14 am
one time i was having problems and i had to run a ground from the battery to the starter to get a good enough connection for it to work
PostPosted: Wed Aug 01, 2012 3:33 pm
Any updates?
PostPosted: Fri Aug 03, 2012 11:42 pm
no not really i am going to mess with it this weekend and see what happens
PostPosted: Thu Sep 20, 2012 11:59 am
well i finely got around to working on the buggy. took the starter back and got a different brand. what do you know it fired right up after a year of sitting almost no more binding and no struggle to turn the motor over. sweet!!!!!!! :D
Now i just have to work on getting it in time and tuning the carb.
