It is currently Tue May 05, 2026 2:49 am
 Post subject: squeeling in cylinder 3
PostPosted: Wed Aug 15, 2012 4:52 pm
I just dont think im meant to enjoy this f'ing thing ive been pissing with it for a few weeks getting some stuff checked out on it making sure its good to go for the ville laborday weekend and wouldnt you know it the mother f$@%er is squeeling in cylinder 3 sounds like a wet belt almost so i pulled the belt off the alternator and started it up for a few seconds and its still there any ideas or tips could my rings have dried out in the cylinder from the carbs dripping fuel in the intake and probably cylinder because the valve seats arent in the best of shape should i change the rings in it or could it be a dry bearing i may just run it labor day weekend and if somethin happens o well lol
PostPosted: Wed Aug 15, 2012 6:06 pm
Was adjusting carve a few weeks ago and noticed the same dam thing. Just like a little wet belt in there. Passenger side quite as a mouse. Behind driver #3 that little squeel. Had to put ear up to it. Not very loud. I was told not to sweat it. Would like to know. My motor runs great. That kind of thing drives ne crazy
PostPosted: Wed Aug 15, 2012 6:47 pm
X2 my cousins rail has a squeel similar to it. And mine is also running fine just hate to hear the noises well looks like im gojust nna run it and keep my fingers crossed labor day weekend id like to tear my motor down this winter just hope it dont trash my brand new piston and jug :roll: s
PostPosted: Wed Aug 15, 2012 8:46 pm
If I'm not mistaking creech said it could have something to do with the airflow around butterfly. Maybe he will chime in. I have hpmx empi 40s. How bout you ?
PostPosted: Wed Aug 15, 2012 8:59 pm
Hpmx empi 40 duals too
PostPosted: Wed Aug 15, 2012 9:02 pm
Im starting to dislike these carbs they are filling my intakes full of fuel when the buggy is just sitting there so i had to put a shut off valve on it. Im about ready to sell them and just go back to a single weber 44
PostPosted: Wed Aug 15, 2012 9:11 pm
spray some wd-40 down that carb while it running and see if it stops. its possible the gas has washed all the oil off the rings. As Ray said it could also be air squeeling past the butterfly if its not set just right.
PostPosted: Wed Aug 15, 2012 9:16 pm
Thanks aaron ill give it a try this weekend and see if it makes a difference it was never there before and isnt a steady squeel its loud then will go away for so long then squeel again if it was the rings i guess you think it would be a steady squeel i would think jmo but you guys know more then i do thanks again
PostPosted: Thu Aug 16, 2012 2:16 am
could be a few different things
1. butterfly's
2. air bypass screw set wrong
3. exhaust leak
4. intake leak at either head or carb end
5. head leaking around cylinder
ive seen all of these at different times make a "sqealing" sound and most sort of came and went except the first to listed they were always a steady sqeal till corrected
PostPosted: Thu Aug 16, 2012 9:37 am
Just guessing some more. Loose spark plug , wrist pin if you don't have teflon buttons,broke ring. Start with a compression check.Get a vacumm gauge and read up on how to read it. They were the scan tool back in the carb days.For ex. , the needle bouncing 1 number was a weak spark plug wire.It will tell you bad valve guide, wore out guide, broke ring etc.
PostPosted: Thu Aug 16, 2012 4:27 pm
but keep us posted on what it was.
PostPosted: Thu Aug 16, 2012 5:28 pm
Will do probably wont get to tinker with it till this weekend or early next week hopefully
PostPosted: Thu Aug 16, 2012 8:47 pm
On the carbs the screws with the 8mm nut on them whats that adjustment for i thought i read somewhere they are supposed to be twisted in till they stopped is this a major adjustment for something or what?
PostPosted: Fri Aug 17, 2012 1:03 am
those are the air bypass screws i refered to, they are used for balancing out each barrel individualy, a lot of folks say run them all way in some say 1/2 or 1 round out, but technically the book ive got says to run them all in, find the one flowing the most and back the other 3 out to match it, however, i usually have pretty good results with all 4 run all the way in :|
PostPosted: Sun Aug 19, 2012 8:21 pm
Sprayed wd down in the carb for that cylinder noise is gone for now thanks aaron and everyone else
