It is currently Mon May 04, 2026 11:03 pm
PostPosted: Wed Aug 15, 2012 9:43 am
The other day me and Slade went to the store in the buggy and on asmall ride. On the way to the store I noticed a lot of smoke comming out of the breather and I was only turning 2800 rpm. When we parked it oil was dripping from the filter on the breather. WHY IS THIS GOING ON?? It is a 1835 with a single carbon running 20/50 oil and is not over filled almost a little low on oil. Anybody have. Some input
PostPosted: Wed Aug 15, 2012 10:20 am
do you have your blow by hose running to your air cleaner? if so you need to change that set up....
PostPosted: Wed Aug 15, 2012 12:54 pm
X2
Could be just not venting properly or maybe cracked ring or something letting blow by. Chad :mrgreen:
PostPosted: Wed Aug 15, 2012 8:34 pm
How and where do I start to check getting the easy and cheapest off the list
PostPosted: Wed Aug 15, 2012 9:15 pm
I am sorry... but I am confused...
Easiest and Cheapest what? What list?
PostPosted: Fri Aug 17, 2012 11:26 pm
I mean how do I find out if it is not venting or if it is the rings. Is it better to start with just changing and cleaning the breather and hoses. How do I find out if it is venting right. What kind of damage do I get running with a broken ring and is there a way to find out which one is broke without pulling all the pistons?
PostPosted: Sat Aug 18, 2012 12:23 am
yes clean breather foam and hoses first and a compression test will probably show you which cylinder has a ring issue
PostPosted: Sat Aug 18, 2012 5:01 am
its normally just cause you need to clean the box and foam inside
PostPosted: Sat Aug 18, 2012 12:55 pm
Ok yhanks guys. Trying to get ready for labor day. Where is everyone riding that weekend?
