| best chemical to cleen cooling fins? http://woodsbuggy.com/phpBB3/viewtopic.php?f=3&t=13902 |
| Author: | hpfreak [ Wed Jul 25, 2012 6:46 pm ] |
| Post subject: | best chemical to cleen cooling fins? |
whats the best chemical to clean between the cooling fins on the jugs and heads? mine are packed with crud and it would take me days to manually clean them out. I just need something to break up the crud so air will flow through it doesnt have to be blinging when its done. |
| Author: | woogiebugger1 [ Wed Jul 25, 2012 8:54 pm ] |
| Post subject: | Re: best chemical to cleen cooling fins? |
The greatest universal solvent known to man. H2O X 3500 PSI = CLEAN. Hold on to them, so you don't have to go to the next county to retreive them ? |
| Author: | BIRDARCHITECT26 [ Thu Nov 01, 2012 4:31 pm ] |
USE OVEN CLEANER IF IT GREASY! PB BLASTER FOR RUST |
| Author: | Roy [ Sat Nov 03, 2012 8:20 am ] |
I use oven cleaner, let it soak then pressure wash. |
