| Vw Engine Building Tip http://woodsbuggy.com/phpBB3/viewtopic.php?f=3&t=13873 |
| Author: | badbrad [ Thu Jul 19, 2012 11:30 pm ] |
| Post subject: | Vw Engine Building Tip |
DONT USE # 2 PERMATEX it sucks. I just built a 2165 motor just got it on my buggy fired it up getting my carbs lined out and the d&mn thing leaks already. Of course the only thing i used the permatex on was around the cylinders. And it already leaks around # 3 cylinder. What is the best stuff to use to seal up my cylinders? |
| Author: | smitty [ Fri Jul 20, 2012 2:51 am ] |
| Post subject: | Re: Vw Engine Building Tip |
Permatex Right stuff |
| Author: | ridenrace6 [ Fri Jul 20, 2012 5:14 am ] |
ive always used the red or orange high temp permatex on the base of the jugs |
| Author: | bugman505 [ Fri Jul 20, 2012 7:48 am ] |
gray high temp is what I use. Did use Indian Head but gets brittle and flakes off to bad. |
| Author: | Maddog [ Fri Jul 20, 2012 10:23 am ] |
smitty wrote: Permatex Right stuff X2 |
| Author: | badbrad [ Fri Jul 20, 2012 10:41 am ] |
The permatex i used must have been non hardening or something because it never did set up like all the other permatex ive used has any of you guys used hondabond i think thats what im going to use this time |
| Author: | RaceBugg1098 [ Fri Jul 20, 2012 12:23 pm ] |
i use red "high tack" |
| Author: | mudd mutt [ Sat Jul 21, 2012 1:03 am ] |
badbrad wrote: The permatex i used must have been non hardening or something because it never did set up like all the other permatex ive used has any of you guys used hondabond i think thats what im going to use this time Brad which Honda bond are u referring to? I use hondabond 4 |
| Author: | hpfreak [ Sat Jul 21, 2012 8:26 am ] |
if im sealing two parts that dont use a gasket I like to use anarobic sealer (spell check). anarobic sealer dries in the abcense of oxygen. so everything that gets pinched btween the two parts dries but whatever squeezes out does not. that way theres no chance of a hard peice of rtv falling off and plugging oil galleys or something like that. |
| Author: | Aaron Creech [ Sat Jul 21, 2012 11:11 am ] |
Permatex Ultra Grey is the best stuff I have found for sealing cylinders. Everywhere else i use permatex aviation sealer. |
| Author: | kevin f [ Sat Jul 21, 2012 11:12 am ] |
I always use the ultra blue permatex. I use very little of to the point of spreading it with my finger. I hardly ever have leaks. |
| Author: | reno2165 [ Sat Jul 21, 2012 2:21 pm ] |
Aaron Creech wrote: Permatex Ultra Grey is the best stuff I have found for sealing cylinders. Everywhere else i use permatex aviation sealer. x2..sealed a few sets and no leaks yet |
| Author: | Roy [ Sun Jul 22, 2012 6:05 pm ] |
Cylinder bases I always use Permatex ultra copper. Never have an issue unless it's not clean enough. |
| Author: | badbrad [ Sun Jul 22, 2012 10:02 pm ] |
Thanks guys for the help i put my i dont know why mine never sealed up right i used number 2 permatex it was black and it never dried even after letting it set for 3 days under a fan. Maybe i was in just to big of a hurry and didnt look at the tube but anyways im going to use something different than what i used haha |
| Author: | turboblue [ Wed Jul 25, 2012 10:41 am ] |
Roy wrote: Cylinder bases I always use Permatex ultra copper. Never have an issue unless it's not clean enough. Ditto |
| Author: | Rick [ Wed Jul 25, 2012 10:51 am ] |
badbrad wrote: Thanks guys for the help i put my i dont know why mine never sealed up right i used number 2 permatex it was black and it never dried even after letting it set for 3 days under a fan. Maybe i was in just to big of a hurry and didnt look at the tube but anyways im going to use something different than what i used haha permatex # 2 is a non-harding sealer |
| Author: | badbrad [ Wed Jul 25, 2012 11:09 am ] |
Well isnt that great my buddy told me thats all he used hell he even bot it sounds like hes screwed up a bunch of motors |
| Author: | m.ralston [ Wed Aug 08, 2012 9:32 pm ] |
Sometimes the top left bolt willl leak oil threw the threads on the #3 cylinder or the oil cooler leaks down on the #3 jug.Just my 2 cents. |
