Loosing oil pressure
http://woodsbuggy.com/phpBB3/viewtopic.php?f=3&t=13872
Author:  dirtdobber [ Thu Jul 19, 2012 5:34 pm ]
Post subject:  Loosing oil pressure
Oil light coming on when high rpms are high.im running 20-50 w oil. Cram oil filter with factory cooler. I have the adapter under factory cooler that has oil lines going in and out to filter. Do I need to get a new high volume oil pump. It's a older engine and I don't know about the shape the oil pumpis in
Author:  kevin f [ Thu Jul 19, 2012 6:36 pm ]
Post subject:  Re: Loosing oil pressure
what size motor? I had one do that once before. My solution to the problem was to go to a stock oil pump. Problem was the pump was sucking all the oil from the motor and causing a bad foaming problem. i would try a stock pump first and go from there.
Author:  dirtdobber [ Fri Jul 20, 2012 2:08 pm ]
It's a 2275, I'll try it . Thanks Kevin
Author:  Roy [ Sun Jul 22, 2012 6:07 pm ]
Try running the sump over full by a quart and see if it still does it.
