| intake getting hot http://woodsbuggy.com/phpBB3/viewtopic.php?f=3&t=13862 |
| Author: | Andrew_Ha [ Mon Jul 16, 2012 6:52 pm ] |
| Post subject: | intake getting hot |
My buddy has a 2180 110 eagle cam has run fine for years now all of sudden the intake is getting hot exhaust is fire hot all within few second of starting it. It is also losing power |
| Author: | kevin f [ Mon Jul 16, 2012 8:05 pm ] |
| Post subject: | Re: intake getting hot |
check the valves and the advance in the distributer. Its prolly gunna be one of the two. Maybe even and intake leak causing a lean mixture. |
| Author: | ridenrace6 [ Tue Jul 17, 2012 1:12 am ] |
x2 what kevin said or maybe a cracked head |
| Author: | BAJABUGNUT [ Tue Jul 17, 2012 7:04 am ] |
I am no expert, but I am thinking valves to, maybe a stuck or burnt valves.. Good luck and let us know what u find.. |
| Author: | Odyknuck [ Tue Jul 17, 2012 8:47 am ] |
Do a compression check. That will confirm a valve issue. After that check for the infamous Air Leak. |
| Author: | Andrew_Ha [ Thu Jul 19, 2012 11:34 am ] |
Pulling heads now to have them checked |
| Author: | Odyknuck [ Thu Jul 19, 2012 1:22 pm ] |
Did you do a compression check and a leak test prior to pulling them? Results? |
| Author: | Andrew_Ha [ Thu Jul 19, 2012 2:01 pm ] |
They didn't say just told me they were pulling |
| Author: | Odyknuck [ Thu Jul 19, 2012 3:19 pm ] |
Ok, who is they? I would not allow anyone to start taking my motor apart with out knowing why. |
| Author: | volksdude2007 [ Thu Jul 19, 2012 8:38 pm ] |
Im thinking they is his buddy with the motor problem |
| Author: | Odyknuck [ Thu Jul 19, 2012 10:11 pm ] |
AH! I missed that buddy part of the first post lol. |
| Author: | Wanted_Fugitive [ Fri Jul 20, 2012 4:23 am ] |
I had the same issue after a complete rebuild of a 1915. Come to fine out it was a simple air leak around my intake boots. But a compression check will definately answer the valve question. |
