| 2276 cam ???? http://woodsbuggy.com/phpBB3/viewtopic.php?f=3&t=13762 |
| Author: | JoeM [ Mon Jun 11, 2012 10:52 am ] |
| Post subject: | 2276 cam ???? |
Ok im running a 2276 cb044 heads 44x37.5 valves and 1.4 rockers and 11.5to1 with straight cut gears and 110 it had great bottom end power but seems to be limited on top i would like some help on what cam would help make so me more rpms |
| Author: | darrell [ Mon Jun 11, 2012 11:42 am ] |
| Post subject: | Re: 2276 cam ???? |
I built 2276 for a friend of mine we used a vz-25 and that thing flat runs we ride with guys with 2500s he runs better than some of them |
| Author: | Aaron Creech [ Mon Jun 11, 2012 6:39 pm ] |
Web-cam 86B on a 105 lobe center. I would put some new valve springs in after running the cam and rocker combo you have now. Are the heads ported? |
| Author: | hyde [ Mon Jun 11, 2012 9:37 pm ] |
I would port the Heads and intakes frist. With 1.4 rockers fk43 or fk44 . fk44 will peck HP with ported head a round 6000 RPMs . with good springs .I would run the FK43 286ad. 253 at .050 and .536lift in a 2276cc eng . Aaron what is Durtion Advertised and .050 and lift. |
| Author: | smever2 [ Mon Jun 11, 2012 9:48 pm ] |
Fk42 and 1.4 rockers |
| Author: | Aaron Creech [ Tue Jun 12, 2012 12:22 am ] |
300 advertised,260 @.050 .536" lift with a 1.4 rocker. It seems like a really big cam but the 105 lobe center will make a huge torque gain down low and still have plenty up top. Also woth the high compression he can get away with alot more cam and honestly it needs it to help bleed off a little cylinder pressure. |
| Author: | JoeM [ Tue Jun 12, 2012 8:58 am ] |
Ok thanks my heads are not ported but they do have dual springs would you still replace the springs and with the 86-B buy the web lifters to go with it who can i get to do the porting and and polishing on the heads |
| Author: | hyde [ Tue Jun 12, 2012 7:37 pm ] |
Where are you ? Cheek with sponsors of woodsbuggy. Drews has some Web cams and liffters and do portting. |
| Author: | Aaron Creech [ Tue Jun 12, 2012 7:56 pm ] |
If the heads are not ported thats why you are lacking top end with your current combo more than the fact that the cam/rocker combo is all wrong. i would suggest getting the heads and intakes ported and see how it runs before splitting the case to do a cam swap. If you put a bigger cam in it now without port work it will probably run worse than it does now. |
| Author: | hyde [ Tue Jun 12, 2012 8:01 pm ] |
Aaron Creech wrote: If the heads are not ported thats why you are lacking top end with your current combo more than the fact that the cam/rocker combo is all wrong. i would suggest getting the heads and intakes ported and see how it runs before splitting the case to do a cam swap. If you put a bigger cam in it now without port work it will probably run worse than it does now. X2 Theres 2500 with 110 and fk43 &1.4 rockes that will run to 7000 with good heads. Peck HP is about 5600RPMs. |
| Author: | Baddvw [ Tue Jun 12, 2012 9:15 pm ] |
hyde wrote: Aaron Creech wrote: If the heads are not ported thats why you are lacking top end with your current combo more than the fact that the cam/rocker combo is all wrong. i would suggest getting the heads and intakes ported and see how it runs before splitting the case to do a cam swap. If you put a bigger cam in it now without port work it will probably run worse than it does now. X2 Theres 2500 with 110 and fk43 &1.4 rockes that will run to 7000 with good heads. Peck HP is about 5600RPMs. x3, mine will run 7,000 rpm with no problems and my heads are a killer set.....S/E ported and polished, 2500cc, 110 cam, 1.4:1 roller rockers. |
| Author: | The man [ Tue Jun 12, 2012 10:54 pm ] |
I agree I have 3 motors and all 3 have a 110 cam in them with a good set of heads and they run good I have a set of s e heads that have all the port work that u can have done to them and they r alsome but the bad thing is with all that money spent on them a stock set of super flows will flow just as much I no they want cool as good but they will give u all the top end u need with bottom end to It will still turn 8 grand with the 110 cam |
| Author: | The man [ Tue Jun 12, 2012 10:55 pm ] |
If u want u can ride one of mine and see what u think |
| Author: | The man [ Tue Jun 12, 2012 11:01 pm ] |
If I was going to change cams I would go with a vz 15 it will turn out of the frame but that is a lot of work when u can make the 110 do nearly the same |
