It is currently Sun May 03, 2026 7:58 pm
 Post subject: oil pressure
PostPosted: Sat May 19, 2012 8:41 pm
i have a ???? how much oil press should i have at idle i have like 6 lbs at idle and like 40 lbs when climig a hill is this to littel it is a stock 1600 duel port with remout oil cooler and filter
 Post subject: Re: oil pressure
PostPosted: Sun May 20, 2012 5:47 pm
Hmm...Im not 100% sure...6 seems a little low? but then again who says the gauge is totally accurate? Think at a HOT idle, i have maybe 10-15? Really id have to go warm it up and check to be sure though.
"IT IS WHAT IT IS"
PostPosted: Sun May 20, 2012 8:24 pm
What kind of oil and what weight are you running and is that when its hot or cold :?:
PostPosted: Sun May 20, 2012 9:21 pm
I am using pensoil 10 w 40 and that is when it is worming up ... changed the filter today and now i am runing about 10 lbs after it is worm was told to run 20w 50 in it with lucas oil aditiv a bout hafe a botel of it ... what do u think
PostPosted: Sun May 20, 2012 10:12 pm
Yeah thats what i would do and use the shortest filter that you can find that will help also .If the oil is getting hot that will make it lose press . If you got a stock oil cooler and the motor has been hot a few times they have rubber seals that will close up when over heated .Then the oil starts running warmer than it should .Anyway iv been told that ...
PostPosted: Mon May 21, 2012 9:04 am
5psi at idle is fine. its not the best but as long as it climbs with the rpms its good. 40psi when climbing is good.
PostPosted: Mon May 21, 2012 12:24 pm
Rule of thumb is 10PSI for every 1000 RPM.
