It is currently Sun May 03, 2026 6:32 pm
PostPosted: Mon Jun 25, 2012 1:00 pm
i decided to give dual carbs a try and i got 2 set but going to try the 40's first. then later try the dell 45's. but i was wondering a good starting point. been running 500 holley and it works good but just want to try something different.
2276
12.5to1
fk-8 and 1.4 rockers
42x37.5 street eliminators
PostPosted: Mon Jun 25, 2012 1:13 pm
I'm running 40's on a 2165.
150-main
50-pilot
200-air
f-11 tubes
good luck hope this helps??
PostPosted: Mon Jun 25, 2012 2:24 pm
My 1915 I got 150 mains , 50 idles, 28 venturis, f11 tubes, 210 airs , 0 bypass and I believe 50 on the pump jets? sprayers.
"IT IS WHAT IT IS"
PostPosted: Mon Jun 25, 2012 9:00 pm
Use the 45s.
PostPosted: Tue Jun 26, 2012 7:59 pm
Don't even mess with the 40's Dave. Put on the 45's. You have way more head flow capability than the 40's can keep up with I believe. I don't thing you can get big enough venturis for the 40's to let them flow enough air. You will not be happy with them. The 45's on the other hand..........hold on!! They will make you smile.
