 Post subject: single to dual port
PostPosted: Tue Apr 24, 2012 4:06 pm
Stumbled on some good heads and intakes(Dual port)
My current motor i pulled out of a beetle is a single port would it be worth the trouble to swap
The single was good for bout 36 horse right and the dual port was around 50?
or would i just be wasting my time
future plans for an ecotec or suby but the wife says i gotta build a house first :roll:
 Post subject: Re: single to dual port
PostPosted: Tue Apr 24, 2012 5:47 pm
definitly worth it as simple as it is to swap everything.
"IT IS WHAT IT IS"
PostPosted: Wed Jun 20, 2012 5:26 pm
the single port has more bottom end then the dualport thats all i ever run are single port with 28 pic carb with the right cam from fat performance and alittle head cutting u would have a screaming little engine i know i built one 100 fly cut heads and split duration cam re jetted the carb and it would plain out run a 1915cc and all mine was is a 1641 with head work and cam
PostPosted: Wed Jun 20, 2012 10:39 pm
Rebuilt a 1600 s/p years ago for a Karman Ghia that had a 367:1 ring and pinion.That 57 hp motor had more torque than hp and would accelerate faaast ! I really hated to turn the car back over to the owner. It was a fun rocket.Had more pull and speed with the motor / trans combination than any Beetle(d/p with 388:1) that I ever messed with.I think s/p beetles ran 412:1 and 436:1 swingarm trans, not sure.Im actually rebuilding one while we speak and wouldn't you know it , a fat stud just pulled thru the block.Always install inserts!It already had a grooved super stud. Now I have to remove the head and jug and fix it. :? Hope it will work.
