| Dual 40 IDF's http://woodsbuggy.com/phpBB3/viewtopic.php?f=3&t=13527 |
Page 1 of 2 |
| Author: | jayrod [ Tue Apr 17, 2012 2:23 pm ] |
| Post subject: | Dual 40 IDF's |
How can i get my idle down? Seems a bit high with the new heads etc, But im out of adjustment, maybe im just having a brain fart here lol |
| Author: | jon williams [ Tue Apr 17, 2012 3:19 pm ] |
| Post subject: | Re: Dual 40 IDF's |
Check for air leaks maybe.... |
| Author: | jayrod [ Tue Apr 17, 2012 3:21 pm ] |
No leaks, issue has always been there of running out of adjustment, and have always wanted a little lower idle Just didnt idle quite as high as it does now . |
| Author: | jkeene0317 [ Tue Apr 17, 2012 3:49 pm ] |
What idle jet are you running and with what motor? |
| Author: | jayrod [ Tue Apr 17, 2012 4:27 pm ] |
50 idles dont see how that would actually effect my rpms at idle much though. |
| Author: | jayrod [ Tue Apr 17, 2012 4:29 pm ] |
Note- everything runs great. There are no jetting issues, Simply trying to drop my idle speed down lower. |
| Author: | Maddog [ Tue Apr 17, 2012 7:31 pm ] |
Do you have any slack in throttle cable? |
| Author: | jayrod [ Tue Apr 17, 2012 7:54 pm ] |
Yea theres slack. the butterflies/arms cant go any further closed. when u back the idle adjustment screws all the way out, theres still a gap there. But thats all the further things move. Chad said bigger idle jets, I bumped them to 55 and it didnt change anything. I cant see changing them anyway since im runnin on the rich side of things anyways and it runs good. definitly cant see going to 60's on a 1915 to get the idle right? seems crazy and Im just confused as hell by it lol |
| Author: | jkeene0317 [ Tue Apr 17, 2012 8:29 pm ] |
I am running a 1915 as well with 55 idle jets, 130 mains, 200 air, and F11 emulsion and mine idles great so there my thoughts are that there is something else wrong causing this. |
| Author: | jayrod [ Tue Apr 17, 2012 8:36 pm ] |
u have single or duals? |
| Author: | jayrod [ Tue Apr 17, 2012 8:46 pm ] |
130 seems low This is my jetting before the 044 heads i just put on- 50 idles, 150 mains, 200 or 210 i believe. also run f11's Every runs flawless. and its not an extremely high idle, just slightly higher than i want. |
| Author: | Aaron Creech [ Tue Apr 17, 2012 8:46 pm ] |
Have you checked the air bleed screws to see if they have been messed with? These are the ones with jam nuts on them. They should be bottomed out. |
| Author: | jayrod [ Tue Apr 17, 2012 8:47 pm ] |
Mind you this is NOT a new issue. Just slightly enhanced with the new parts. |
| Author: | jayrod [ Tue Apr 17, 2012 8:52 pm ] |
Yep. Turned them in when i put the carbs on last year. I'll double check tomorrow, but not seeing that being the problem. lol |
| Author: | Aaron Creech [ Tue Apr 17, 2012 8:56 pm ] |
Do your butterflies have holes drilled in them? |
| Author: | jayrod [ Tue Apr 17, 2012 8:58 pm ] |
nope, and visually cant see any gap around them. To rule out twisted shafts. |
| Author: | buggiejunky [ Tue Apr 17, 2012 9:42 pm ] |
if all these things r correct like u say then it shouldnt even idle maybe put corks in the venturies that might bring it down lol |
| Author: | jkeene0317 [ Tue Apr 17, 2012 10:25 pm ] |
Mine are dual 40's and it runs great. |
| Author: | jayrod [ Tue Apr 17, 2012 10:43 pm ] |
buggiejunky wrote: if all these things r correct like u say then it shouldnt even idle maybe put corks in the venturies that might bring it down lol lol Ill try that tomorrow!! |
| Author: | Go Big Or Go Home [ Wed Apr 18, 2012 12:10 pm ] |
Its just those 44's wanting to play! |
| Author: | RaceBugg1098 [ Wed Apr 18, 2012 12:29 pm ] |
check if your fuel enrichment pistons are stuck or gone. they are the 2 little holes with brass lock washer looking things holding them in when you have the top off looking at the float bowl. |
| Author: | jayrod [ Wed Apr 18, 2012 12:36 pm ] |
Thats something I havent heard yet, thanks racebugg Ill check it out. |
| Author: | jayrod [ Wed Apr 18, 2012 4:04 pm ] |
Well, took a minute away from working on other things to check the air bleed screws, they were screwed in. so check that off for sure. |
| Author: | Odyknuck [ Wed Apr 18, 2012 4:57 pm ] |
Your absolutly sure you do not have an air leak? Sprayed evrywhere with ether? Also what is your timing set at? |
| Author: | jayrod [ Wed Apr 18, 2012 6:06 pm ] |
positive, on air leaks timing is 30-32 due to numbers gone off of my pulley and a mark was made before they were totally gone. I cant be EXACTLY sure. |
