 Post subject: 1641+DP RUNNING ROUGH
PostPosted: Tue Mar 27, 2012 8:11 pm
After performing much needed maintenance on my rail (1641+dual port) this winter its running rough as a cob. Rebuilt/rejetted carb, new intake manifold gaskets/boots, new exhaust,new 009 distributer( one advance spring removed), new plugs, along with replacing the gen with an alternator. Won't idle smooth below 1600rpms and one side ie cylinders 3&4 are running hot compared to cylinders 1&2. Valve clearances are .004. I can't find any manifold/exhaust leaks. I have not checked compression yet. Any suggestions guys?
JSWIFT
PostPosted: Tue Mar 27, 2012 8:17 pm
what carb? got the timing right?
"IT IS WHAT IT IS"
PostPosted: Wed Mar 28, 2012 7:48 am
Yep, timed 15deg btdc on idle/ 32 deg btdc max at high rpms. Carb is a rejetted Solex 34PICT3. New plugs, wires, choke wired open. I don't understand why two cylinders on one side are running hot. I guess its going to come down to a compression check when I can get my guage back.
JSWIFT
PostPosted: Wed Mar 28, 2012 8:17 am
Just spitballin, but might have 2 plug wires crossed? Doubt it though.
PostPosted: Wed Mar 28, 2012 9:35 am
15 deg seems way high at idle. I would try maybe putting the other advance spring back in, retiming it to 32 degrees at 3500 and see if it'll drop the timing somewhere between 5 and 10 btdc at idle.
Want me hold your purse so you can use the skinny pedal like a man?
PostPosted: Wed Mar 28, 2012 10:14 am
Triple checked the firing order on the plugs. Yea, the idle timming is high but thats how we run them around here. I'll swap out the distributer with a mild one I have laying around and see what happens.
JSWIFT
PostPosted: Wed Mar 28, 2012 9:20 pm
.004 is too tight on the valves...set em on a snug .006 and see if that helps
i had similar trouble with my new motor getting hot on one side..could hold your hand on one valve cover and cook a hotdog on the other. once i done the valve geometry and "tuned' the motor, it took care of that problem
LEGALIZE BLUEGRASS!!!
Save a tree... eat a Beaver
PostPosted: Wed Mar 28, 2012 9:58 pm
I'm betting it has a vacuum leak somewhere. If it has any valve lash at all thats not the problem. In fact if you are running steel pushrods they should be set at a loose zero. You have already checked the firing order so thats out
PostPosted: Wed Mar 28, 2012 10:12 pm
Im with Aaron set the valves on zero.
PostPosted: Thu Mar 29, 2012 8:24 am
I'm having the condition Reno desribes. I'll recheck for intake leaks and reset my valve clearances which are now at .004-.005. (with steel pushrods) this weekend.
JSWIFT
